Has anyone found a way to adapt or change the fuel filler neck on a 63 full size to work well with the newer smaller gas pumps nozzles? I always run into the gas pouring out all over when I gas the car up.
Are there adaptors out there to fit in the neck to help with this? Idea or suggestion? |
You are filling the tank too fast. The air can't get out. When it gets close to full slow down. You won't have a problem.
Thanks I will give that a try.
I understand the problem. Goatracer is right. Takes patience to get it to show full on the gauge.
Thank you. I will try the next time I fill up.
