| The Body Shop TECH General questions that don't fit in any other forum |
The time and amount of sand my plain bucket kit uses is a lot. Small spray area.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I'm not an expert. I have messed around with some sandblasters over the years. I will say that trying different air pressure can help. Start around 40 PSI and work your way up. Air pressure is about the only adjustment the simple bucket style blaster has.
What type of abrasive are you using? Sandblasters are deceptively simple but, the details to make them effective and efficient are complex. That's why cheap ones are $30 dollars and expensive ones are $30,000. Water jet blasters make dust control easy. In addition they give your grit a boost as wet media is heavier than dry media so it looses less momentum between the end of the nozzle and the work surface. Which can help or hurt depending on what you trying to accomplish.
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
I believe. OP is asking about Pressure washer sand blasters.
Not regular media blasters.
Send it! It’s going home on a trailer. |
