0awg battery ground
4awg alternator positive post to battery (.02v loss) I should've included the Awg part, my badd. Big battery and alternator grounds really helped my car.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
Probably a bit on the huge side, but not horrible, and no harm done except the extra weight.
What size is the battery-to-Starter cable? 4-gauge? There is NO reason to have one side of the circuit four gauge sizes larger than the other side of the circuit. Unless you've got some monster alternator, AND heavy electrical loads, that's just silly. That's starter-cable size, not alternator size. Hanging that much copper off of the lil' stud on the alternator is risky. Factory gauge would have been...10 or perhaps 8. Six-gauge would easily be enough of an "upgrade". Around here, the parts stores are stocking 6-gauge cables on the display rack as BATTERY CABLES. (Yes, that's way undersized for a battery cable for anything with a real engine.) WHAT is your starter-motor amperage draw? The old 10MT, "High Torque" starters on select big-block cars would draw up to 225 amps, but most vehicles were between 170--200. WHAT is your alternator output in actual testing by lowering battery voltage with a carbon-pile? (Not the phonied-up "rating", over-estimated for marketing purposes.) |
My records state (I have 3 cars I go deep restorations on)
0awg battery to starter 0awg ground off battery 160amp alternator, built locally, every document I've seen said that if I actually need 140+ amps 4awg wire. The original alternator to starter was 8awg, there was a .8v loss at the battery. Then I added an 8awg ground on alt case too head and 4awg 3ft to battery, now only a .02v loss, can't really get better. Only a .7-.9v drop in volts while cranking, Lithium battery helped here too in other ways.
will do, will also be testing the alternator for running output.
Tom I was in your same situation decades ago...
Hot start issues This is when I went overkill and updated both battery ground and positive wires. This helped only a little bit. If you're battery is truly good.... My solution was mini, high torque starter with heat shield. This was the fix in my situation, battery was good and battery wires were good and that still wasn't enough, needed a better starter. Old engine was 11.3 compression. You'll get there and at least you'll have upgraded new parts that should cure possible future issues.
Don't muck around with a wimpy battery. Odyssey AGM group 24. At 840 CCA you won't find any higher. Also made in the USA!
https://www.napaonline.com/en/p/ODYO...NnhVTs2Wv4jdBs |
Loosening the belt eliminating a screech may indiicate a bad alt bearing. Take the belt off and turn it by hand to see if you can detect a bad bearing.
Having the belt too lose will cause slippage, so that is not a solution, either. george
| The Following User Says Thank You to george kujanski For This Useful Post: | ||
well the alternator is toast. Screaming loudly now regardless how tight the belt is and the battery is not charging. It is a Powermaster unit but I'm not sure what the output is. I just ordered a 150 amp replacement because my car has ac, aftermarket stereo with large amp and bass speaker, power drivers seat and power antenna.. Hopefully it will solve my problem. I still intend to install the 1/0 battery cables and starter heat shield.
Well at least you know the battery will take a charge .
On a side note here it’s a easy 45 minute job to replace the two Alt bearings if you have a 1/2 drive impact gun and the needed size socket , but it can be done in a bench vise with 12” adjustable wrench a long with the needed size Allen wrench. Be sure to pack the new bearings well with wheel bearing grease. I think putting new bearings in was the first hands on thing I in middle school auto shop way way back when.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 09-14-2025 at 04:21 PM. |
I used this guide to get my alternator to battery loss to be .02v instead of the .8v prior, same setup. 6awg seems plenty if you go alt to battery 3ft etc and similar ground off alt case rear hole and you're back in action.
My opinion is that you don't need a giant output alt unless you have electric fans. Those are the biggest power hogs where you need lower RPM, high current outputs.
George
so you're saying a 150 amp alternator is likely overkill and I understand that. My only real concern is if the stock alternator to battery wiring will be okay or will it need be to be upgraded to a larger diameter. I believe the stock wire is about 10-12awg? If that's the case then I'll send it back.
The only conditions that the alt provides high current is if the lod demands it. Your loss are are not unless your audio is, say 200 watts, in which case it's probably providing 20 amps to that. Add in headlights, about 10 amps, etc. You probably will never use even half of the max capacity., so no sense in going crazy with cable size at the alt.
George
Editing.. your loads are not large unless your audio is like 22 watts per channel, that may be 40 amps or so. But intermittent.
George
#38
Edit... again...darn fingers 200 watts per channel.
Hate typing on the fone... George
#39
As long as you are running a CS130 alt with single positive post and have the open hole for the external ground.
You can easily add an 8awg ground wire off the alt case. Pic 1 **My newer alt has the hole on the rear vs the side bracket like this Powermaster XS. You can easily add a 6awg wire off the single alt positive post to the battery. Pic 2 You can now run any alternator and not worry about the wiring losses/efficiency.
#40
Have you checked the pinion to flywheel clearance? Flywheels grow when they get hot.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
