Old 09-16-2025, 09:46 AM
Well, if you need some, email me at home, will dig for them. Think I have some bolts too. Doubt I have a full set, but will check.
Old 09-16-2025, 10:10 AM
Found this too, lists part numbers and torque specs. Also found a pic of the rods w new bolts, the rods are still in my 461 (now 463).
ID:	657251   Click image for larger version
ID:	657252   Click image for larger version
Old 11-24-2025, 10:57 PM
scott70's Avatar
scott70 scott70 is offline
Took my engine over to the machine shop today with my list of things I wanted done and checked. Told him I wanted the connecting rod bolts replaced. Tonight I was thinking about if there is a certain amount of times you can heat up the small end for press fit pistons. Let’s say you’ve changed pistons a few times and they’re press fit. Does it make the small end weaker if it’s been done a couple of times? He’s rebalancing it to make it internal balance. He’s probably got to remove the pistons from the rods to do the balance?
