#41
I usually start the car as soon as the electric pusher pump is under a load after the fuel line fills up to the mechanical pump. I don’t wait for the electric to fully fill the carb, once the mechanical pump has fuel to it, the engine does not have to crank over very much to start (about 3 seconds) |
#42
If you don't have any kind of shut off system and you have the ignition on, the pump turns on, then what? The pump just runs and floods the carb?
#43
Longk ago i enjoyed the notion of using the oil idiot switch to enable the Dizzy & Bright Oil alarm light. Add pusher pump enable, and it's all good. Cube relays to do it right.
Also has "Speedo-Alert" to crowwbar such stuff, but that became a nuisance. Was typical for my car to have Carter pusher pump into stock mech pump. Was good even with return tap plugged..
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
#44
If the carb’s needle/seat are working correctly and the fuel pressure is set correctly the electric pumps should not flood the engine. You can pull the site plug out of a holley carb and walk off and forget the pump is running, come back an hour later and the engine will start right up. Years ago I had a Predator carb on one of my cars and the needle and seat didn’t hold and if filled a cylinder full of fuel and bent a connecting rod. I am not sure the oil safety would have caught it because you have to bypass most of them until the engine starts. That would be far less likely to have happened with the Revolution safety or a mechanical pump with the pusher pump. The electric pusher pumps I have done do not blast much fuel thru a non operating mechanical pump. |
| The Following User Says Thank You to Jay S For This Useful Post: | ||
#45
Cranking to get oil pressure to activate the pump will take just as long to start as a mechanical pump deal filling the carb. What the idea of those switches assume is that there is already fuel in the carb, as there should be, don't know why you guys are going dry but that's a different problem. Anyway with fuel in the carb and in the squirter circuit, the car will fire off on that, it doesn't need fuel pressure, and once it fires off, oil pressure builds and turns on the pump. That's how they typically work. As far as the pump running when you turn the key on, it doesn't flood the carb. If it is you have a needle and seat problem, again a different issue. |
#46
My TA I cut out the mechanical and just have the electric. Mechanical was a restriction as well as a source for heat.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#47
If you want to go the pusher pump route, the carter elect pump is probably the best bet for what you want... but going with the tanks inc set up allows for future upgrades to EFI and will supply the q-jet much better than a mech. But again for a pure street car, all that may be overkill if all you want is to fix a hard start issue after sitting awhile and dont have any drag racing or auto crossing plans. A primer/pusher pump fixes that for under $100 vs well over $1000 for intank set up. https://www.summitracing.com/parts/crt-p4070 |
| The Following User Says Thank You to 78w72 For This Useful Post: | ||
#48
#49
As for starting up, my car right now starts instantly if it has been run in the last 72 hrs. I like it so much I even posted a video about it, LOL. After 3 days though, it gets dry. I think that's probably normal for a Qjet. If it was a DD, it would always fire up instantly. If I went with the oil pressure switch, then putting a bypass switch in the car would take care of priming after a 3 day rest and also if the oil pressure switch fails. BTW, do you know if they fail open or closed? Or is the failure thing even realistic or overblown?
#50
#51
If you do decide on the primer/pusher set up for now, then the carter is the best bet IMO. But bypassing all that to go intank pump is the better approach... hope you consider even just some fun time at teh drag strip during a test & tune event just to see what your $20 grand engine can do, especially if youre looking into sticky tires and full intank pump/EFI... |
#52
I've got sticky tires back on it now, the Nitto NT01. I haven't tried to hook with them from a stop, but from a roll they stick pretty good. At WOT in first they get a little loose but not bad.
#53
About two years ago. frustrated with the same issue you're describing with the empty fuel bowls, I decided to ditch the mechanical pump and went with the Tanks Inc setup with the in-tank 450lph pump and 1/2" supply and return. Used a cheap quickfuel bypass regulator plumbed-in after the carb, no hobbs switch. I didn't expect any performance gains, since the car ran really strong on the street with the M&H drag radials, 495cid, 4sp, 4.10 gears. But after the electric pump install I was shocked at how quicker the engine pulled to redline. Like I said before, it ran great on the mechanical pump, but there was a noticeable difference after the Tanks Inc set up. So the dry fuel bowl issue is solved and a slight fuel starvation issue that I didn't know about is also solved. And if I decide to go EFI, most of the components are already in place
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto Last edited by Singleton; 09-20-2025 at 11:40 AM. |
| The Following User Says Thank You to Singleton For This Useful Post: | ||
#54
#55
On the subject of a qjet fuel bowl going dry, there was a thread about this sometime last year that I cant seem to find, I think you (jhein) started it and "FJ" posted a test he did putting a full cup or more of fuel in a container on the garage or house counter, he said it didnt lose any fuel after like 3-5 hours so I/we/you have something else going on.... well, just last week I remembered that thread and how the test wasnt what fuel does when in a hot engine/carb... I filled a tablespoon or a little more of fuel in a small metal container, about the size & amount of fuel in a q-jet bowl, I set it right on top the carb after a short drive but fully warmed engine at ~180°. After letting it sit with hood closed for about 1.5 hours I came back to check & sure enough it was completely dry, not even a residue of wet fuel left. Granted inside the carb isnt exposed to open air but the carb is fully vented. That test is more of a real world scenario for fuel in a q-jet than a big cup of fuel at room temp, based on what I found after a short time, fuel definitely can & does evaporate at a pretty fast rate when heated like an engine. This was non ethanol fuel too. Why some carbs/cars dont have this issues is beyond me, but it is a very real problem for many cars when they sit for a week or more, probably a combo of things from evaporation to drain back depending on the mech pump used? |
#56
So about 2 weeks ago I decided to remove a RobbMc in line fuel filter that I had right before my pump after I realized that it wasn't needed since I have a sock on my pickup and the Qjet filter in place. I had to move the car before I did the job so I knew the bowl was full. When I removed the line from the pump, not a single drop came out. The next day when I went to start it, it fired right up instantly like always. So I don't seem to have any drain back. I believe it's just good old fashioned evaporation which in my environment with my fuel takes about 3 days after a hot shutdown. It's also likely that most of it occurs while the engine is still hot. With the hood down and the air cleaner in place it probably stays warm for quite a while. Once it cools down the process must slow down.
| The Following User Says Thank You to jhein For This Useful Post: | ||
#57
OK, well, I just ordered the new Tanks inc setup. I'm planning on removing everything this week and then putting in the new stuff when it gets here the following week. Yeehaw.
#58
Which tank & pump size did you order? Which sender? What set up for return line & regulator? They offer a notched tank that fits some applications better. Please start a new thread with pics & details on the parts and installation as you go along. |
#59
I went with the square tank, slightly larger capacity and I'm not planning on tubs (famous last words). I got the GPA-4 pump, Carb regulated plumbing kit, wiring kit, tube sender. I also got the Russell tool to push the tubing onto the fittings.
#60
Any advice on what type of sealer to use on the fuel pump block off?
