I am going to install the dipstick tube first and get it fastened to the cylinder head where the tube bracket aligns perfectly with the bolt hole.
Someone mention in another post that it was imperative that the bracket aligns perfectly or the tube will be misaligned at the transmission and leak. |
I probably had one of those originally and tossed it out to use a dangling rubber hose between the carb and vacuum modulator so it rests on the hot exhaust and dry rots to allow a vacuum leak. Or that it collects a coating of oil and dirt and decomposes.
It sure gets expensive having been young and dumb. Don't get me wrong. I changed a little: I'm only older now. I figured that I could bend a hard line from NAPA by copying a picture from a vendor, and fasten it properly to the transmission. I haven't been under the car for years, and I keep finding things to put back correctly. It feels good emptying that bin of leftover parts I ended up with from my youth. Last edited by East; 10-03-2025 at 01:22 PM. |
I installed the dipstick tube into the transmission first, and then the upper cooler line. It took some time to tighten the upper coolant line because the amount of wrench turns allowed by the space available.
The lower coolant line was much easier to tighten. I have to attach the the dipstick tube bracket tab to the cylinder head without distorting the angle of the lower tube going into the transmission. The pictures that I posted were not of my transmission. I found them on the Internet when I was trying to locate the dipstick tube. I was using them as an example of how the dipstick is formed around all of the surrounding components. It's funny that the dipstick that I removed fit with one added bend. Too bad the bend kinked the tube. I bought an o ring kit for the speedometer. I am going to try one member's suggestion to use two o rings on the vacuum modulator. The only other parts penetrating the transmission case are the detent shaft and the kick down connector. I have to purchase a good pan gasket. I bought a tube of Permatex Automatic Transmission Gasket Maker. Should I just use the sealer without a gasket? I have read many posts of members trying to pinpoint transmission leak. From looking at the pan, it looked as though it was at fault, but it was sealed really well. It was hard to remove. As others have stated, the fluid collects around the pan making it seem to be the leak. Last edited by East; 10-05-2025 at 04:40 PM. |
