Old 10-11-2025, 09:10 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
It won't fit if you plan on running a tripower.
Old 10-14-2025, 04:50 PM
oldman66gto's Avatar
oldman66gto oldman66gto is offline
Not trying to steal the thread, but have a 428 w/HEI in my '66 GTO.
Am going to hve tri-power installed when I get back to Florida.
What would be the best "standard" size HEI distributor to replace the current one?
Currently has an Edelbrock 4-bbl on a "Torker" intake, with the "HEI" distributor.
Thanks for your suggestions.
Allan Bishop
Old 10-14-2025, 06:52 PM
67Lemons 67Lemons is offline
Allan Bishop
Standard issue HEI won’t fit with tri-power, you’ll need to either use a modern small body HEI or Ready to Run distributor or a points distributor.
1972 GTO
Old 10-14-2025, 07:33 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
Allan Bishop
Another option is the conversion system from M&H wiring. I converted my stock points distributor several years ago and have not had a problem. I also installed the voltage regulator conversion from the same dealer with no problem.
https://www.wiringharness.com/
The Following User Says Thank You to fyrffytr1 For This Useful Post:
