Pontiac engineering U.P.C codes tell the progression of engine development and the time span of usage in many cases.
The code only changed when significant changes were done for the most part. A few brief examples. L-74. All high comp 400 4bbl medium performance motors from 68 to 70. L-78 all low comp 400 4 bbl medium performance motors from 1971 to 1979. L-67 1968, RA1 D port, RAII round port, so where into the round port era now. L-67 1969 and 70, RA4 motors except in the F body . These RA4 engines in 1970 got a LS-1 code L-75 base line 455 engines. LS-5 1971-72 455 round port HO. LS-2 455SD. So the 455SD was in development as early as 1971 The LS-2 U.P.C code is to me the most likely reason for all the number 2 stamping on your heads there. Note that once engineering got to making a 455SD 16 preproduction casting that they put the air injection boss back in across the top of the exh ports in case they needed to add a air pump to meet emissions. Here are molds of an Intake and Exh port from a non ported 455SD production head.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 10-27-2025 at 05:02 AM. |
| The Following User Says Thank You to steve25 For This Useful Post: | ||
2001 Trans Am,WS6 Sunset Orange Metallic (sold) 1973 Trans Am 455,4speed 1970 GTO |
| The Following User Says Thank You to 73T/A For This Useful Post: | ||
As an example a 1969 Chevelle could have been ordered with an L78, and so could a same year GTO; In the case of the GTO it was the ‘base’ 400/4bbl engine - for the Chevelle it was much more special. Here is my correction of the engine codes which Pontiac used, and what I removed from above: L-30: 350/2bb 1968-1977 L-65: 350HO 1968/69; 350/4bbl 1974-1977; best 350 you could get for the given year L-67: 400 ‘Ram Air’; 1967-1968.5 ‘D-port’; 1968.5-1970 ‘round-port’; the best 400 you could get for the given year L-74: 400HO 1967-1969(?); “RAIII” 1969-1970; one step down from the L-67 L-75: 455/4bbl 1970-1976; “bread and butter” 455 performance engine for which ever model year L-78: 400/4bbl 1967-1979; “bread and butter” 400 performance engine for which ever model year LS1; (purported) RAIV-SD 1970; did not pass pre-production stage.
