Originally Posted by jhein
This is the exact type of failure that killed my motor when I was a kid. The #8 exhaust valve came loose and got sucked into the cylinder. I'm guessing I was at a higher RPM when it happened compared to you based on the damage I had. It obviously destroyed the piston, broke the rod, blew the cylinder wall wide open and also cracked the crank. The only major engine component that was salvageable was the driver side head. It was nasty.
I was in the garage when it happened. Engine was still cold. I was at 12-1500 rpm. My choke sucks sometimes so I try to help keep things going. Had about 30 seconds of run time on that start when the shinola hit the fan.
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry!
- Mike
1967 GTO
