Old 10-29-2025, 12:19 AM
unruhjonny's Avatar
I believe your stock grind was a 067;
This grind is virtually unobtainable.
If you stick with an OE grind, there’s no messing around or worrying about anything.
As I have understood it a 068 should work fine - that is what the 70-RAIII & 71/72-455HO all used.
I personally would not step down to a 066 grind.
Others here will probably have better first hand knowledge or opinions than me.
If your cam looks good, and you have the time you could try measuring it.
1970 Formula 400
