Old 11-05-2025, 05:25 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
Default FlowKooler water pump
Originally Posted by Squidward View Post
If you will be using the 8 bolt pump, I would say just make sure your pump doesn't rub with the plate, and call it good. The FK impeller design has its own plate design to make the impeller more efficient: water goes in at the center, gets flung by the vanes to the outside where it is directed to the 2 block channels. A factory pump might need a little plate massage for efficiency, but I don't think the FK needs massaging.
color me gone
