Putting together my 70 gto and ran into an issue with the passenger side tie rod hitting the sway bar. Driver's side has about 1/2 to 3/4 inch clearance. Using the ridetech coil over conversion kit. Sway bar is a 1.25 inch diameter bar. The passenger side tie rod is almost against the bar. Both coil overs are adjusted the same. I don't know if i have the right idler arm or do I need longer sway bar end links? Anyone else have this problem using the big front sway bar?
