Old 09-09-2025, 10:15 AM
MJZ's Avatar
MJZ MJZ is offline
Default Endura Options
The Endura front cap of 71 Judge continues to show more spiderwebbing every time I look. Any suggestions would be of help. Is the a option of replacement repair or re-coating?
Old 09-09-2025, 11:08 AM
John Milner's Avatar
Probably the best way to repair would be to take the bumper down to the bare rubber and spray/block SPI Epoxy primer and repaint the bumper.
The Following User Says Thank You to John Milner For This Useful Post:
Old 09-09-2025, 11:23 AM
MJZ's Avatar
MJZ MJZ is offline
I've been afraid to even remove as I understand the thing is so brittle. I assumed the cracking is the endura, it is just the paint that shows it. Which makes sense because the paint never flakes off anywhere.
Old 09-19-2025, 01:47 PM
69Customs's Avatar
69Customs 69Customs is offline
They. Had a show on Detroit muscle recently that showed how to check cracking depth with windows cleaner and how to fix cracks with epoxy 2 part. They had about 50 cracks to repair. Called the car the henchman.
Old 09-19-2025, 04:51 PM
tjs72lemans tjs72lemans is offline
Best way to fix is to have it blasted to bare rubber. You may see no cracks if it was just the paint. If the rubber is cracked, the two part epoxy filler is the way to go. Then SPI epoxy which is actually flexible even when dried and cured. Regular epoxy is brittle and cracks, as yours has. I was actually pulling and bending mine after paint, trying to adjust bumper and no cracking. Even 5 years later.
Old 11-03-2025, 12:15 PM
Jeff McDonald Jeff McDonald is offline
3m 05891 2-part flexible epoxy. stuffs amazing. there are articles out there on how to strip clean and prep endura -READ them. this is not a production shop repair. My endura had lean on cracks, front end was bumped and deformed endura on nose and body shop sanded it off . it's been going on 2 years, no cracking or lifting. spent more time on this nose than anything else on car. yours is smaller so thats good.
ID:	659932   Click image for larger version
ID:	659933   Click image for larger version
The Following 2 Users Say Thank You to Jeff McDonald For This Useful Post:
Old 11-05-2025, 06:09 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
Thanks for posting that. I need to jump into some endura repairs soon on a '68 and a '71-72 and forgot the go-to 3M product. It does look like they discontinued that product number and now list it as 05887 & 35887 (depending on small/large 2-part epoxy tube size) but retained the same product name.
Thanks 👍
Old 11-08-2025, 02:35 PM
android 211 android 211 is offline
Don't be afraid to sandblast it. I've done 2 and it gets off everything you don't want left behind without paint remover residue. Sanding takes off too much good rubber.
Old 11-08-2025, 06:22 PM
Considering the size and shape of the '71 endura, that might be a prime candidate for a fiberglass or carbon fiber replacement part. It certainly would be much easier to graph on than a 70 or earlier one, or the 70-73 F body ones.
There are some out there that actually restore endura bumpers exclusively, and you can purchase one already repaired and ready to bolt on and finish. Not cheap, but some of those places will give you a core refund for a salvageable one.
Remember too that not only Pontiacs came with enduras, so places that specialize in the other makes are potential candidates for repair.
I know Paul at Fast may do just a bumper specifically, you could ask him.
Places like Legendary and Restore a Musclecar might also know someone reliable that could repair one, they deal with them frequently.
There are also used repaired ones that are on eGay that you might be able to find, a little risky, but you could probably homework it and reduce the risks.
There is someone who is reproducing the 68-69 GTO endura bumper, OPGI sells them, you could find out who makes those, and maybe see if they can do a run of the 71-72 endura, but that may have a considerable lead time.
https://www.opgi.com/bumpers-hardwar...o-G240103.html
Places like Ultra-Carbon and Anvil make carbon fiber replacement parts, they may consider doing one for the 71-72 GTO. The Anvil one has all the brackets that house the grills and headlights for the 70-73 firebirds, as well as many other cars, so it is possible. Probably not a cheap option, but still an option.
https://anvilauto.com/pages/1970-1981-firebird-transam
https://www.ultra-carbon.com/product...amarofirebird/
If you plan on doing it yourself, load-up on homework before you dive in. Here is a pretty good place, Paul at Fast is a great resource, pretty sure he still lurks here sometimes, and SPI has a forum that is also a good resource:
https://www.spiuserforum.com/
These things are getting more scarce by the moment, as are the people who can properly repair them, it's a shame but the way it is.
Just throwing out options here....
Old 11-09-2025, 12:30 AM
BB70's Avatar
BB70 BB70 is offline
X2 on sandblasting- its fun ! Don't stay in one spot, keep moving.
Old 11-11-2025, 09:32 AM
scott70's Avatar
scott70 scott70 is offline
https://forums.maxperformanceinc.com...d.php?t=833566
This is what I did and 6 years later there’s no signs of any cracks
