#361
Old 11-10-2025, 07:13 AM
Would be curious on the weight of that too!
And apologize for any hijack....
  #362
Old 11-10-2025, 08:36 AM
SD455DJ SD455DJ is offline
HWYSTR455, No AC as BVZ said with the RAIV. It has power steering, am/fm with rear seat speaker, HD cooling/SST required w/RAIV, ride & handling, and center console for options (I did add factory gauges, hood tach and formula wheel). It usually weighs in between 4050 and 4100 lbs. depending on how much gas is in the tank (half/full). The lightest I ever got it was 4030 lbs. with half tank and no spare/jack. It's a pig.
Most '70-'72 GTO's are in the 3900 - 4200 lb. range depending on options. We don't see a lot of difference between the 3 years at the pure stock drags in comparably equipped GTO's.
Dennis
  #363
Old 11-10-2025, 09:08 AM
Whew. So that could potentially put me in the 4700 lbs range....
Glad I did a 535!
  #364
Old 11-10-2025, 09:19 AM
Glad I did a 535!
I think you'll be in the 4000 to 4100 lb. +/- range curb weight (w/o driver, full fluids). I'll be interested in the 4-corner weights!
Dennis
  #365
Old 11-10-2025, 09:22 AM
That would be much more acceptable, and yes, will post info once I get it!
Thank you for the insights!
  #366
Old 11-10-2025, 09:30 AM
I know it's a B-body, but Dan's recently acquired '69 Catalina Ventura weighed 4202 lbs. w/o driver with half a tank of gas. It has the 428, dual exhaust, PS, PDB, TH400, HD cooling, the Ventura option (nicer interior and insulation), as major options (no A/C). I would think your GTO would weigh 200 lbs. less than the Cat with your options/modifications.
Dennis
Name:	69 Cat Weight 1.jpg
ID:	660417   Click image for larger version
Name:	69 Cat Weight 3.jpg
  #367
Old 11-10-2025, 09:38 AM
HWYSTR455, No AC as BVZ said with the RAIV. It has power steering, am/fm with rear seat speaker, HD cooling/SST required w/RAIV, ride & handling, and center console for options (I did add factory gauges, hood tach and formula wheel). It usually weighs in between 4050 and 4100 lbs. depending on how much gas is in the tank (half/full). The lightest I ever got it was 4030 lbs. with half tank and no spare/jack. It's a pig...
Dennis
ah ha! now we know the culprit here - my repop Custom Sport wheel is stuffed with Helium, Hydrogen and Liteium
This from another section; 71 convert w/chrome nose, aluminum radiator, Gen V 5.3 and TKX
Weights:
Front: 2,100
Rear: 1,820
total: 3,920
54/46 weight split
This with me, and some cargo (220 pounds) and full fuel and compact spare tire.
so 3,920 minus (220 + 120 + 15) equals 3,565
Not as light as I wish for all the lighter components installed but nothing else can be removed without affecting pleasure of driving.
  #368
Old 11-10-2025, 09:44 AM
Must be the helium in the Sport Wheel...lol! That's really light for a convert...even with the LS/TKX. 3800 lbs. with driver...not bad at all. It'd be at least 4000 lbs. with the original Pontiac engine.
Dennis
  #369
Old 11-14-2025, 03:56 PM
So was having troubles scheduling my corner weighing with local shops, most scales cap out at 1000 lbs each, and felt I would exceed that. So I figured I would get a total weight as a starter.
I went to a truck scale, the scales have 3 pads, the 2 first pads ae a little closer together, guessing to be able to calculate cab weight, and be able to determine cargo weight with the 3rd pad.
So with me not in the car, 3/4 tank of gas, total weight came in at 4280, with a front/rear split of 2360/1920 respectively. (see attached pic)
Gas (90/10 ETH, depending on season) weighs an average of 6.2 lbs per gallon. Tank holds 6.2 lbs x 23 gallons (142.6 LBS), so minus 25% (35.65) of 23 gallons = 106.95 lbs, if I did that math right.
4280 -106.95 = 4176.05 lbs
Less than I thought, but, technically, since I'm calculating corner weights for actual driving conditions, I should be using full tank curb weight, which is measured weight of 3/4 tank adding the 1/4 tank of 35.65, for a total of 4315.62 lbs.
That is closer to my guess-timate, the truck scales may have been certified by %, and a 2000 lbs scale will have less of a variance than a 50,000 lbs scale. But it still gives me a ball park.
I will keep look for someone to corner scale for me so I can get more accurate numbers, just wanted to close the loop on this for this thread.
  #370
Old 11-14-2025, 05:01 PM
Shiny Shiny is offline
Sorry you had to get creative to find a scale but sounds like you found a way.. and no, that wasn't intended as a pun but I won't deny it happened....
I looked at the 1970 and 1971 AMA Weights for the A-bodies, and the difference between a comparably equipped Lemans Sport to the GTO (I used 1971 optional equipment weights as most weren’t listed in the 1970 table):
1970
Lemans Sport 2-dr Hdtp Coupe 3456 lbs. (base inline 6?)
400 4-bbl. V8 279 lbs.
HD 3-spd 29 lbs.
Dual Exhaust 29 lbs.
V8 Coolant add 13 lbs.
Total: 3806 lbs. (25 lbs. heavier than the GTO???!!!)
GTO 2-dr Hdtp Coupe 3781 lbs. (no options)
1971
Lemans Sport 2-dr Hdtp Coupe 3360 lbs. (base inline 6?)
HD 3-spd 29 lbs.
Total: 3710 lbs. (117 lbs. heavier than the GTO???!!!)
GTO 2-dr Hdtp Coupe 3593 lbs. (no options)
So, the AMA weight tables don't seem to be a good way to compare…unless the Lemans Sport wasn’t standard with the 250 inline 6…?
Dennis
Is a 70 LeMans Sport really heavier than a 70 GTO? Front bumper and brackets?
A 350 can't weigh more than a 400... it's a small block, right?
I guessed the split was 55/45 a few weeks ago when I was trying to compare rear springs. scarebird actually measured 54/46 on his 71, so I was happy to see that.
  #371
Old 11-14-2025, 05:12 PM
...I guessed the split was 55/45 a few weeks ago when I was trying to compare rear springs. Scarebird actually measured 54/46 on his 71, so I was happy to see that.
You must remember that a Gen V weighs about 395 pounds, much less than the P400 at 650+.
Also, I have the battery in the right side of the trunk, shifting that weight to the rear.
  #372
Old 11-14-2025, 06:08 PM
Is a 70 LeMans Sport really heavier than a 70 GTO? Front bumper and brackets?.
No.
That total had V8 weight added versus Inline 6
The Sport comes with V8
The nose difference , boxed rear arms versus open arms , and rear sway bar , maybe tiny amount on coil springs if thicker.
Sport probably less than 200 pounds lighter
That's both cars with 3spd floor shift
  #373
Old 11-16-2025, 06:34 PM
I couldn’t respond as I was gone for the weekend and just got back. The Lemans Sport was standard with the 250 in-line 6 as per the attached…hard to believe. I’m sure it wasn’t a popular combination, but there may be some surviving examples out there somewhere. According to the 1970 and 1971 AMA weight tables the 350 2-bbl weighs 19 to 22.3 lbs. less than the 400 4-bbl.
Mike, as BVZ said, the GTO is roughly 200 to 225 lbs. heavier than a comparably equipped Lemans Sport/Lemans hardtop respectively, and closer the 250 lbs. for the Tempest/T-37. For instance, my ’70 RAIV Judge weighs 4100 lbs. with driver compared to my ’70 400 4-bbl Tempest coupe at 3800 lbs. with full tanks & spare in the trunk.
Dennis
Name:	1970 Model ID Data 2.jpg
ID:	660836   Click image for larger version
Name:	1971 Model ID Data.jpg
ID:	660837   Click image for larger version
Name:	1970 Axle & ID Chart.jpg
  #374
Old 11-17-2025, 08:19 AM
Those are dry weights correct? Or curb?
I don't have a spare in mine. How much do those weigh?
I don't have a jack in there either.
  #375
Old 11-17-2025, 09:21 AM
HWYSTR455, spares (full size) & jacks are 50 lbs. or so, together (14x6 steel wheels, not Honeycombs). The weights in the Parts Catalogs are most likely shipping weights with 3 gallons of gas, but I'm not sure on that point. They are different than the AMA weight tables which seem to be heavier. I'll have to do a comparison now that you've got me curious about the differences.
Dennis
  #376
Old 11-17-2025, 06:20 PM
I knew my car was going to be a porker, threw a lot of stuff in it.
Add me and a passenger and that's a conservative extra 400 lbs. And add 2 more and that's another 400. Toss some luggage in the back and it will quickly exceed 5000 lbs. Crazy.
I may need to add boost. I made the SCR low enough where I can easily add 8-12psi.
  #377
Old 11-17-2025, 06:37 PM
For what it's worth, I made a chart listing the AMA and MPC weights for both 1970 & 1971 A-body 2-Dr hardtops. Remember, these are all base models with no options, so 6-cylinder engines in the Tempest/T-37, Lemans, and Lemans Sports. I hope it's legible. It's strange that the MPC weights for the '71's are the same between the Lemans and the Lemans Sport and only 5 lbs. more than the T-37...which I don't believe.
Dennis
Name:	1970-71 AMA-MPC Weights.jpg
  #378
Old 11-17-2025, 08:53 PM
I'm giving up on those charts .Worse than asking a woman her weight.
The Following 4 Users Say Thank You to Baron Von Zeppelin For This Useful Post:
  #379
Old 11-18-2025, 06:15 PM
Agreed! They make no sense at all.
Dennis
  #380
Old 11-19-2025, 05:19 PM
Today we went over to Tim's garage to pull the front end off. Fist time we pulled the fenders off the car since we got it in Feb. 2014. You can see his '62 Chevy II convert in the background. We have to wash the SW desert dust off all the areas we exposed next to clean and repaint, including the inner fender wells. The bottoms of the front fenders are nice and solid metal.
Dennis
ID:	661030   Click image for larger version
ID:	661031   Click image for larger version
ID:	661032   Click image for larger version
The Following 5 Users Say Thank You to SD455DJ For This Useful Post:
