Old 11-13-2025, 09:32 AM
dv657172's Avatar
dv657172 dv657172 is offline
Default Headlight Wire Harness routing
On my 71 & 72 the Headlight Wire Harness runs through the Core Support Wiring Grommet (pic 1) on both sides of the Core Support but is not attached to anything in between, its just draped across (pic 2).
The 72 Service Manual shows a total of 4 clips that hold the harness to the core support (Fig 12-62) and Ames sells them for this application (P104) but I dont see where they could be attached.
Which is correct? If there should be clips where do they attach to the core support?
DV
ID:	660633   Click image for larger version
1965 GTO Cameo White, Red Interior - 389, ST300 numbers matching
1965 GTO Black, Black Interior "Post" car - 389, M-20 numbers matching
1965 GTO Silver, Black Interior 100% dedicated drag car w/1968 400(461), 16x Heads, TH400, 3.90 9" Rear 1.656 60' 7.566 90.057 (1/8th)
1971 GTO Black (orig. Quezal Gold), Gold Interior - 400, TH400 numbers matching
1972 GTO Cardinal Red, Black Interior - 455, TH400 almost numbers matching
Old 11-13-2025, 08:55 PM
Jimbobeast Jimbobeast is offline
There should be plastic clips attached to the core support. Look carefully, or I suppose they could be missing.
Old 11-13-2025, 10:46 PM
dv657172's Avatar
Definitely no plastic clips. Havent seen the holes for the clips either. Can you send a pic where yours are?
Old 11-14-2025, 08:30 AM
Not without taking the nose off. I won't be back home until after Thanksgiving.
Old 11-14-2025, 09:49 AM
dv657172's Avatar
No problem. Will do some more looking on mine. Appreciate the replies.
Old 11-14-2025, 07:20 PM
Mr. G Mr. G is offline
On my '71, there are three clips holding the headlight harness. 2 plastic ones located directly behind where the horn brackets attach to the core support on the vertical part and one metal clip in the center attached with a bolt also on the vertical part and under the horizontal hood latch brace where it attaches to the core support. The plastic ones pop into a small hole in the core support. Hope this helps.
The Following User Says Thank You to Mr. G For This Useful Post:
Old 11-14-2025, 07:25 PM
Sounds like my '70
Old 11-14-2025, 10:01 PM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
page from 72 assembly manual
Old 11-15-2025, 11:00 PM
dv657172's Avatar
DavesGTO - thanks for all the info. My Service Manual had the same pic but until you mentioned they were behind the horn I didnt see them.
Interestingly the PS one seems ok assuming I have the correct hole (pic 1) however the DS one will need to be opened up somewhat it appears (pic 2 with horn removed) and the horn bracket completely blocks it when its installed (pic 3).
I dont see anything in the manual diagrams regarding the center clip, is this the hole you referred to in pic 4. Can you send a pic of the bolt and clip you mentioned.
Thanks for your help and patience
DV
Name:	PS behind Horn.jpg
ID:	660795   Click image for larger version
Name:	DS behind Horn.jpg
ID:	660796   Click image for larger version
Name:	DS clearance issue.jpg
ID:	660797   Click image for larger version
Old 11-15-2025, 11:29 PM
DavesGTO's Avatar
Center clip is referenced as #10.
The Following User Says Thank You to DavesGTO For This Useful Post:
Old 11-16-2025, 05:42 PM
dv657172's Avatar
Looking at the Assembly Manual diagram it would appear that there is only one plastic clip used behind the PS horn bracket and one metal one in between the two horns. If I am seeing that correctly then it would explain why there isnt a good hole or clearance for a plastic clip behind the DS horn bracket.
Old 11-16-2025, 06:40 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Here is a pic from a 70 upon disassembly. You can see that 3 out of the 4 plastic clips failed. Only one holding the harness up.
Old 11-16-2025, 08:51 PM
dv657172's Avatar
Thanks Bruce
Interestingly on my 71 (not sure yet on my 72 but likely) it is just like the Assembly Manual diagram that DavesGTO posted. I have confirmed one hole for the plastic clip right (#3) behind the PS horn bracket on the core support and a hole and a square cut out right in the center of the core support. The square cut out looks to be for sliding the nut (#9) in place and the screw holding the clip (#10) goes through the hole.
