#521
I thought it sounded just a touch hotter than a 068. Nice.
#522
The 744 is the original 'Ram Air' camshaft;
Keep n mind that "Ram Air I", "Ram Air II", and "Ram Air III" terms are not PMD coined terms - they were applied later as a means of grouping engines - it helps that the 'Ram Air IV' lends to this working out quite nice (it was not coined "IV" because it was the fourth). This cam was used in all the 1967 'Ram Air' engines (aka: "Ram Air I"); It was used in the manual backed 1968 D-port 'Ram Air' engines (aka: "Ram Air I"); It was also used in the early manual backed 1969 'Ram Air' engines (aka: "Ram Air III"). Essentially for 1968 & 1969 the automatic backed engines received a downgraded to the "HO" cam; By the end of the 1969 model year all D-port 'Ram Air' engines received the "HO" camshaft - this was carried into 1970. (Also in 1969 there was a greying of the distinction of the 'Ram Air' versus 'HO' 400cid engines. Although it has been lambasted by some, I love the 744 cam.
| The Following User Says Thank You to unruhjonny For This Useful Post: | ||
#523
Got the master installed. I ended up disassembling and cleaning the original 70 distribution block and brackets, hitting them with a little brass cleaner using steel wool. I ended up painting the brackets gray, as the original plating was smoked. I think it looks pretty good!
Even bigger news, I was able to take the car down the street! The first time the car has turned a wheel under its own power since 1999. I gave it an eyeball alignment and tightened the front-end down, a quick bleed of the brakes, and let it get up to temp. I'm happy to report no weird noises, no grinding, no pulling, and a smooth engaging clutch! Here's some pics of the brake system. Boy GM really made a screwy system for 1970. ![]() ![]() ![]() ![]() ![]()
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
| The Following 4 Users Say Thank You to 72projectbird For This Useful Post: | ||
#524
Looks great!
Can I ask where you got the plastic retainer that holds the washer fluid hose and wiring harness on the inner fender well? I've been looking and haven't been able to find them.
#525
I got them from Ames. I can't find them on their site though. I know they're in the book. I'll see if I can grab the part number for ya
| The Following User Says Thank You to 72projectbird For This Useful Post: | ||
#526
[QUOTE=72projectbird;6593112]
Here's some pics of the brake system. Boy GM really made a screwy system for 1970. QUOTE] Not sure about the power brake option, but on non-powered brake system we discovered the brake lines are unique to the 1970 model year and were difficult to source. |
#527
OK, now that I have the good close up pic of yours it looks like it's the FP100A. Is that right?
#528
Yup, those are them. They fit extremely tight, so it'll take some force to snap em in.
#529
On the subject of these brake components;
I recently came across a listing on another site for a 1970 bake master/booster combo, and went to compare what I saw there against what I pulled off my car; I did see that the stamping at the front of the reservoir was there; EB ('E' was very faint, but the 'B' was captured in a photo with out too much difficulty) Booster number 0426 (rear of top tab); Date 132(?; front of top tab; obscured by front half of case). I did not flip my stuff upside down to get the casting numbers or date off the reservoir, as it still a complete assembly (c/w short lines attached). I saw the markings on the proportioning valves(?); The listing I came across for that other set, didn't explain any of the markings from the smaller proportioning valve(?) - can anyone explain what the markings indicate? Yours / mine line 1: KH / KH line 2: R / R line 3 (4x size font): K / K line 4 (vert after large 'K'): 055_0 / 135_0
#530
The blue and green fittings on the brake lines won't be correct on a restoration of this level.
Best I can remember. The 055_0 and 135_0 are likely production Julian dates. |
| The Following User Says Thank You to Baron Von Zeppelin For This Useful Post: | ||
#531
I'm flattered you guys think the car is on the higher levels of restoration. I know there's a few things that are incorrect, but I've definitely been trying to make it as nice as I can while still being able to drive it a decent amount per year. Means a lot coming from you guys on here!
#532
KH is Kelsey Hayes. Not sure on the big K or the R
So long, farewell. |
#533
72projectbird, I probably missed it somewhere, but could you tell me who did your radiator? Thanks.
#534
It's not that far from me, so I just dropped it off and picked it up directly.
#535
Thanks!
#536
Tires finally came in after 11 months!
Stepped it up to a G60 to help fill out the wheel openings and give it a slightly wider footprint. Should look awesome. Already have the correct lugs and nos center caps, just have to get the tires mounted and balanced. I'm gonna try and avoid having any balance weights on the front of the wheels, but sometimes it's unavoidable with steel wheels. ![]()
| The Following 2 Users Say Thank You to 72projectbird For This Useful Post: | ||
#537
Not trying to hijack your resto 72. Are these the correct colors other than the lines are stainless? They look really close to the same as 72's project. Just put mine together. Very nice work on the 70 TA 72
White/Blue 71 455 HO T/A Auto Blue/Blue 71 455 HO T/A 4 Sp White/Sandalwood 71 455 HO T/A 4 Sp White/Black 70 RAIII T/A M21/373 (stripper) Carousel Red/Black 69 GTO Judge 4 Sp 2002 Firehawk Red/Black 6Sp |
| The Following User Says Thank You to skunkwerks For This Useful Post: | ||
#538
1972 GTO |
#539
Cool. I'll be curious to see how they look. I went with the FR60s on mine.
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
#540
Got the tires mounted. All weights in the back. Nos center caps and reproduction 70 lug nuts.
I think they look awesome. The long wait sucked, but man, they really change the look. I like the height and width of the G60. I took a pic of one next to another Rally II wrapped in a 245/60 and they're pretty damn close.
