Just bought and newbie on big cars. Wanting to convert to hideaways. What years will work? Are the grills the same GP and Bonnie?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Tri power, 4speed, barn find 1966 GTO Ragtop 1969 GTO Judge RA lll, auto 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Factory stock oval track car |
I am fairly certain the 68 GP and Bonneville hideaway bumpers and headlight doors are the same. Also believe some Bonnevilles came with the hideaways as original equipment, whereas they were standard on GP.
Ok thanks, in the market for a 68 GP hideaway setup too
Ditto rustyrelic. The front end of a '68 Grand Prix and '68 Catalina\Bonneville\Executive are the same fit. Grand Prixs are where you should start your search as all of those came with the hideaways and I've only seen a handful of Bonnevilles with them over the years.
It's not a trivial swap but it isn't overly difficult either as it is just bolt-on stuff. There's a LOT to get than just the bumper\hideaway light doors as well - the switch in the dash is specific, the vacuum canister, and vacuum lines are all needed |
Does anyone have a schematic for the 68 GP hideaway setup?
I don't have a schematic but it is easy to explain,
...vacuum source comes off the back of the carburetor with a check valve on the line. ... Line from carb goes to a T fitting, one line goes to top of driver side inner fender to connect to reservoir can (next to battery). ...other line from T goes through firewall at grommet to headlamp switch ...two other hoses go from headlight switch through firewall (same grommet) to a connector ...connector connects to two hoses integrated into forward headlamp harness. ...each hose exits the lamp harness near the horn support ahead of the rad support ...each hose goes to a T fitting with hoses going to both actuators (one hose feeds bottom of both actuators, the other the top) Question, do the fullsized cars need unique hideaway frame to bumper brackets (like the GTO did) or did they use the standard brackets?
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & a 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 2 Bonnie Cvt's & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
Thanks for info and replies. The whole setup would be nice, but I’ve done a couple a bodies and converted over to electric with good results. I’m assuming, of course the door mechanisms are similar to the a bodies?
My friend has a 68 GP setup he parted out many years ago. All the components look the same but are probably slightly different dimensionally.
I'm curious if the 67-68 big car hidaways inverts the headlamp bulb buckets the same way as the 68-69 A cars did?
Best bet would be either the assembly manual or the illustration section of the MPC.
