| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
What are you guys putting in your parts washer? Need a good strong cleaning fluid.
Tractor Supply PSC 1000
79 Trans Am WS6 71 Formula 72 Formula 71 Firebird 69 Firebird |
| The Following 2 Users Say Thank You to hojs69 For This Useful Post: | ||
Gasoline and right-sized buckets.
AI?
72 Lemans sport 462 auto 75 Trans Am 4 speed 39k miles |
| The Following 2 Users Say Thank You to Skidmark For This Useful Post: | ||
Spray Nine.
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
| The Following User Says Thank You to Elarson For This Useful Post: | ||
I've always used solvent (PSC1000 in recent years) in my harbor freight parts washer. Inherited a second HF unit a while back and filled it with slightly diluted purple power concentrate (cheaper but not as effective).
The PSC1000 works better - by far - and also safer when it comes to aluminum, etc. I generally only use the purple power for soaking/prewashing really filthy steel parts and often do a final touchup/rinse in the solvent. Over the years I've also snagged some half empty cans of mineral spirits at garage/estate sales for cheap/free and dump them into the solvent tank to top them off. |
| The Following User Says Thank You to bdk1976 For This Useful Post: | ||
For cleaning parts outside, try Dawn Powerwash. Great stuff!!!
Fun faxt: pistons soaked in gasoline overnight will let the carbon deposits brush off with ease.
Had good luck in a HF parts cleaner with stoddard fluid.
Only if they come with the correct pump. Most fail because they use the wrong solvent/cleaner.
So long, farewell. |
| The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s |
I have a Jegs parts cleaner which is probably the exact same unit as the harbor freight one. Ill X5 the Tractor Supply stuff.
To me it was the best blend of, cost and safety for a solvent based material. Gasoline probably works better for cheaper.......but I dont have the best spark dicipline in the world when Im working. So I didnt want to have a source of gas vapor floating around.
| The Following User Says Thank You to RocktimusPryme For This Useful Post: | ||
Good solvent destroys the pumps I've tried. Anyone found a pump that will last and not fail?
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Little Giant 51855, used for many years with PSC 1000.
See link: https://www.amazon.com/Little-Giant-...iglink27338-20. Ignore price, can be found much cheaper. I also put a recirculation filter, drains, etc.... on my cheapy HF washer. Works great.
| The Following User Says Thank You to hojs69 For This Useful Post: | ||
