Old 12-13-2025, 08:16 PM
Default EFI sale!
So have a few different systems two are older.
New in Box complete Holley Commander 950! New was over $1200! from Summit in 2002! Fuel pump still new and you could probably pull the pods out of the TB and use for a 900 cfm TB on port system on the cheap. It will replace your ECM if you are running one. I think it takes a narrow band at one time could be upgraded to a wide band. Free plus shipping!
New I had updated 2008 firmware FAST system for sequential with wiring harness and a 3 BBL billet 4150 base TB like an Accufab. Even the new Chinese Speedmaster 4BBL billets are normally $326. Got it from Gregg here on PY years ago. $400 plus shipping.
Newer system a FAST EZ tb system tune in computer for a 327 SB. Pulled it off my new 64 Vette. Was running. Sensors, ECU just no fuel pump. I swapped on a Holley Stealth to look more like a carb. $300 plus shipping
ID:	662138   Click image for larger version
ID:	662139   Click image for larger version
ID:	662140   Click image for larger version
ID:	662141   Click image for larger version
Old 12-13-2025, 08:17 PM
Here is picture of EZ system
Old 12-14-2025, 09:27 PM
performerrpm's Avatar
how much shipping to oklahoma 74352 on that fast set up?
Old 12-14-2025, 09:28 PM
i wonder how well that fast tb works with rowdier type cams
Old 12-16-2025, 12:08 PM
I'll weigh it and see. I'll also see what throttle blade size it is , pretty sure a 4 injector one.
Old 12-17-2025, 12:08 PM
9lbs I figure maybe 30.00 shipping. . 1.75 butterflies.
Old 12-17-2025, 12:57 PM
Talked to my buddy that helps me with EFI He was not sure it has the adjustability for a very rowdy cam.
Old 12-18-2025, 11:58 AM
i got a 290b6 i was gonna throw in a 406....that ez set up may not be the best choice for this
Old 12-18-2025, 05:04 PM
Yea hate for you to be disappointed.
Old 12-18-2025, 05:11 PM
lol...at 330....its almost worth the risk tho.
