Old 12-20-2025, 08:44 AM
Cardo's Avatar
Cardo Cardo is offline
Default Alignment at home
Anyone doing their own alignment at home? Specifically, I'm wanting to know what equipment you're using and are you happy with it. All of the good alignment shops around here have closed up, and as we all know if you want anything done right you have to do it yourself. Not interested in the Quicktrick stuff. Looks cheap and overpriced to me. Some of the AutoSolo stuff looks good to me. Are you using two rim clamps or doing one side at a time? Let me know what's working for you.
The Following 2 Users Say Thank You to Cardo For This Useful Post:
Old 12-20-2025, 03:09 PM
https://gyraline.com
I have one and I’ve just begun trying it out doing toe and camber, seems worth the money.
I checked it against my wife’s 2023 Civic with 8k miles on the clock and it seems dead on, pretty much at zero toe and such.
Old 12-20-2025, 07:06 PM
turbo69bird's Avatar
A little long winded but looks like it gives a good description of how to use it
https://youtu.be/xZjc5cxVZC8?si=PM8AulPHKW0RXQrj
Not sure what the benefits of G2 -g3 are but G1 looks fairly useful
960 HP @ 11 psi, 9.70 at 146.
Old 12-20-2025, 07:13 PM
Another instructional video for this one.
Good pick Bart I like it .
https://youtu.be/A0Cd1eWdnk4?si=5N7hHVIMZklEQgCm
Old 12-20-2025, 07:53 PM
Some Amazon/Ebay turn plates and a Longacre caster/camber gauge. Since I have aluminum wheels also bought a cheap wheel fixture. String it and 2 tape measures for toe in/out
https://www.ebay.com/itm/17699719711...caAsLqEALw_wcB
https://www.ebay.com/itm/317443054732
https://www.summitracing.com/parts/l...kaAtPPEALw_wcB
Old 12-20-2025, 08:26 PM
Cardo's Avatar
I saw the Gyraline. Tell me more if you can. I also found a couple of videos of tuner - alignment shops complaining about repeatability. I think their concerns are valid - especially on the modern rims with no weight lip on the outside. I think it's a great concept but I don't think they quite have the interface for that type wheel. I"m really liking this for toe setting. https://www.youtube.com/watch?v=Bcra_qYsJ6g
Old 12-20-2025, 09:23 PM
dataway's Avatar
dataway dataway is offline
Timely topic, I just set my GTO down on some teflon sheets to do this.
I made a 1" square tube bar that fits just inside the bead lip on my 14" steelies. Plan is to use my Klein tool magnetic digital level to get the readings, in addition to strings, lasers etc.
I tried the Gyraline, it says my MotoG 5 is not accurate enough.
I thought there was a sticky somewhere on PY with a step by step for home alignment.
Old 12-20-2025, 10:09 PM
SR-71 SR-71 is offline
My QuickTrick alignment kit worked well on our buddy Ron's 66 LeMans.
The Following User Says Thank You to SR-71 For This Useful Post:
Old 12-20-2025, 10:29 PM
tstroud tstroud is offline
I have been using Gyraline for a while on cars and medium duty trucks. The repeatability seems to depend on how repeatable you can be when holding it to the wheel. It works easily for camber and toe. You will need some turn plates for caster. The more you use it the easier it gets.
Old 12-20-2025, 11:47 PM
mrennie's Avatar
mrennie mrennie is offline
I aligned my GTO with the Tenhulzen alignment kit and only have ~1700 miles on my tire but the car drives straight, no pull, and no abnormal wear yet.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
The Following User Says Thank You to mrennie For This Useful Post:
Old 12-21-2025, 02:51 AM
Isn’t this basically the same kit for a lot less $$$
https://www.ebay.com/itm/375194391390
Old 12-21-2025, 11:28 AM
I could not get greased linoleum sheets or double garbage bags to work for turn plates for me. I initially got the Quick kit. It is good for toe and camber that is about it . When you do a caster sweep the wheel tilt and you have to be able to zero the level to compensate and the Longacre gauge is the only way I found to do that.
Old 12-21-2025, 11:46 AM
Beers Beers is offline
It doesn’t appear to have the sensor unit (the small box with the digital readout that senses changes in angle). Without that, I don’t see how you could check camber or caster. Odd that they mention those in the title
1968 GTO Aegena Blue
Previous: 1970 Firebird Formula 400, 1964 Catalina, 1968 Firebird, 1967 Firebird 400 conv
The Following User Says Thank You to Beers For This Useful Post:
Old 12-21-2025, 03:33 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
The home alignment kits are so-so. Contact the High Schools around you to see if they have an Auto Shop. After retirement I assist the Auto Shop teacher at my local high school. We welcome clubs to come in and show off their cars and we do free alignments on classic cars. Go to your district web site to see which school has an Auto Shop class and the teachers email address should be listed. It's a great way to teach alignments, especially since new cars have no front camber adjustment and all the parts are usually rust free.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
The Following 2 Users Say Thank You to HoovDaddy For This Useful Post:
Old 12-21-2025, 03:40 PM
https://www.ebay.com/itm/14592981739...PPY17YW1QEMT2G
The Following User Says Thank You to turbo69bird For This Useful Post:
Old 12-21-2025, 10:13 PM
Cardo's Avatar
Skip Fix in his post is pretty much the way I was / am thinking I am going to go. Possibly a pair of the wheel fixtures and a pair digital gauges posted earlier or something along those lines so I can set up both sides at once. I like this spring loaded bar for toe - mostly because that was what my old school alignment guy used. https://www.ebay.com/itm/143019857563 I like but don't like the idea of the school.... really a little paranoid about what could get messed up with the students.....slipping bar, dropped wrench etc. Helpful input everyone. Thanks.
Old 12-22-2025, 09:50 AM
Probably not the time or place…are y’all aiming for 3.5 to 4.0 degrees of caster? 1/8 to 1/4 positive camber?
Old 12-22-2025, 01:06 PM
65madgoat's Avatar
I shoot for at least 4+ degrees caster(or as much as possible) and up to negative 1 camber.
QuickTrick here shown by FMG:
https://www.youtube.com/watch?v=NF7NQgZtx_U
Old 12-22-2025, 06:42 PM
Tarl Tarl is offline
I have no clue how Gyraline measures toe-in without a corresponding device somewhere else.
1966 Lemans convertible 455/5spd
1968 Firebird convertible 400/4spd
Need more Pontiacs!
The Following User Says Thank You to Tarl For This Useful Post:
Old 12-22-2025, 07:06 PM
Goatracer1 Goatracer1 is online now
When I did alignments for a living I used every kind of equipment available. Some was very crude and some was very complex. The one thing in common was the fact the "bed" had to be level. It was checked a couple of times a year and recalibrated if necessary. How do you DIYers make sure the car is level. Also if you are taking measurements of the rim you have to compensate for tire/wheel run out.
