my guess is that's from needing a line hone. It was fine from the factory but it would be better with a hone. that being said if you didnt know it was there it wouldnt make a dfference. Do you know what the clearances are?
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
| The Following User Says Thank You to mysticmissle For This Useful Post: | ||
I’ve got some plastigauge and I’ll be checking clearances shortly. The goal like I said is to clean it up with new bearings and rings, after seeing the bearings I’ll make sure that I run brushes through all of the oil passages as well just to be safe.
1972 GTO |
I second the line honing recommendation. Uneven wear from misaligned mains. If the only uneven wear was Pic#2, (high spot), I would have said a spec of debris was on the saddle when the bearing was installed.
Triple Black 1971 GTO |
| The Following User Says Thank You to NeighborsComplaint For This Useful Post: | ||
