Was this originally a 750 cfm Q jet and you ground the rings off, changed the booster design and milled out the ring in the venturi and it still wasn’t as good as the stock 71? So was the WOT better than the 71? What do you use to get inside there to grind that ridge out? Do you think taking the ridge out it lost velocity? Thanks!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
You can read earlier post for your questions: Post #1 outlines parts used Post #35 milling machine Post #76 base plate throttle bore resizing, milling machine No mods to venturi shape When outer ring is removed drastic signal loss Area was much larger than a 455HO casting so signal loss maybe greater Definite increase in area WOT, others who have done this mod street & strip can confirm Goal was to regain some signal strength to match the 455HO while gain primary airflow and low speed drivability This lead to three other approaches that I started to experiment. If you take a try post up your results Thanks
Carburetor building & modification services Servicing the Pontiac community over 25 years Last edited by shaker455; 01-11-2026 at 10:58 PM. |
Later experiment I had machined a 750 venturi to an 800 leaving outer ring in place like an SD-455 casting.
Carburetor building & modification services Servicing the Pontiac community over 25 years Last edited by shaker455; 01-11-2026 at 11:22 PM. |
| The Following User Says Thank You to shaker455 For This Useful Post: | ||
How did that work,That’ s funny I’ve been thinking of doing the same but to a 800! I don’t have a mill tho �� so it will be by hand
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's Last edited by grandville455; 01-12-2026 at 09:22 AM. |
