Old 01-14-2026, 04:15 PM
78w72 78w72 is offline
Originally Posted by srmmmm View Post
That is a bit concerning. The cam lift on the XE276HR is .502/.510 and the recommended Comp springs were installed with the rebuild. All the valve spring seats were milled to the same height for correct pressures. The polylocks really do stick up high on these rockers.
I may be doing a tear down soon if my rings don't seat (2300 miles on the engine and still going through a quart of oil in 600 miles), and will consider changing the studs then. Thanks for the tip.
Over .500 is pretty good lift that would justify 7/16 studs for sure IMO. Especially with a roller cam.
I kept the stock studs on these heads because on a previous 455 6x-4 motor with the same size .480 lift cam I had, I never had a problem after almost 100k hard miles. On this 400 engine I figured they would be ok too and they have been for 15+ years, but after having 1 break I will be changing them out ASAP.
Yeah 2300 miles & still burning a qt of oil there is something wrong...
Old 01-15-2026, 10:44 AM
peters23 peters23 is offline
Make sure you check for clearance between the valve retainer and the oil seal at full open lift. The oil seal bosses often need to be cut down lower to add clearance.
Old 01-15-2026, 01:30 PM
Why would changing the stock studs to 7/16 studs require checking or cutting down bosses to add clearance?
Old 01-16-2026, 12:40 AM
srmmmm's Avatar
srmmmm srmmmm is offline
Thanks for the suggestion. I'll pop a valve cover off and take a look. I imagine I would be able to see any damage to the top of the seals.
