Old 01-25-2026, 05:32 PM
johnta1 johnta1 is online now
IGN 1 is the Pink with Black Stripe.
IGN 2 is Pink.
But the Pink with Black Stripe goes to a splice with a lot of other wires. Out of that splice one of the wires is the resistance wire that goes to the firewall connector.
The Pink wire also goes to that firewall connector, same number position on connector.
On the engine side of firewall the connector just has one wire come out at that position, which is Pink and goes to the coil. There is no external resistor wire or extra wire that goes to the coil.
That resistance wire I am not real clear on what color is, White with Orange and Purple stripes?
The coil gets lower voltage when in Run position, only 12 volts when cranking.
