Old 01-28-2026, 11:19 PM
Ramairnacho Ramairnacho is offline
Default 1970 emissions fuel tank
I bought this tank and was removing the old hoses and the vent tube broke at the solder joint I think. Is this an easy repair or did I ruin the tank? I put it back in the hole and it's tight doesn't move. I didn't realize it's so fragile.
ID:	664334   Click image for larger version
ID:	664335   Click image for larger version
Old 01-29-2026, 06:33 AM
Held for Ransom's Avatar
I would think a radiator repair shop could fix you right up, provided there's one still around.
So long, farewell.
Old 01-29-2026, 09:55 AM
78w72 78w72 is offline
If its just a normal solder joint you should be able to re-sweat the solder in the joint like home water pipes using MAP gas. I had a leaky trans cooler fitting on a factory radiator I did that to and it sealed up fine and was leak free for 15+ years until I sold the car still leak free.
Old 01-29-2026, 01:40 PM
72projectbird's Avatar
Soldering or brazing it back on should be pretty easy.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
