Old 11-01-2025, 02:05 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default Blinker problems
When turning on signal light switch, either way both front signals blink at the same time. Rears work fine. New Kwik wire harness. This is on a 63 Lemans.
The Following User Says Thank You to hobbygto65 For This Useful Post:
Old 02-06-2026, 01:10 AM
emreee emreee is offline
When turning on the signal light switch and both front signals blink together while the rears work fine, it often points to a grounding or wiring issue in the front circuit, especially with a new Kwik Wire harness installed. Double-checking the front grounds and connections can usually solve this, much like troubleshooting details in fc mobile mod setups where small wiring errors cause big effects.
