Old 02-12-2026, 06:15 PM
charlie66's Avatar
Default With a stroker motor with aluminum heads what is the compression ratio limit for pump
Is 10.5 to 1 a safe doable compression ratio for the street on 91 octane with a 461ci with aluminum heads? I used to think so, but I have guys telling me that it is pushing it. Where are you guys at with your street cars that are pushing 500+hp? the cam I'm using is 521/540 lift .050 is 236/242 on a 110. Please share
My Half AN Injun.....
Old 02-12-2026, 06:31 PM
JLMounce JLMounce is offline
My 465 with KRE D ports is right at 10.3:1 and uses a 240/248 on 112 hydraulic roller. 580hp, 600tq. I use 91 octane pump gas in it, but realistically I could probably run 87 mid-grade. If I knew I was going to be traveling long distances and not pushing the engine, I would probably do that.
-Jason
1969 Pontiac Firebird
Old 02-12-2026, 06:57 PM
jerry455 jerry455 is offline
My 468 is 10.5:1 and on the dyno it made no difference between 30-36* timing. I run 93 octane pump gas. I have Edelbrock Performer RPM heads, ported with bigger valves and a 241/251 at .050 hyd. roller cam with .618 lift with 1.65 rockers. It made 580 hp and 590 tq.
The Following User Says Thank You to jerry455 For This Useful Post:
mgarblik mgarblik is offline
I am at 10.1:1 with D-Port Edelbrocks and a solid flat tappet cam. A little under 500 HP, (487) 540 Torque. My engine runs just fine without a hint of detonation on 89-91 Octane non-alcohol fuel. If I had to do it all over again, I would bump the compression to 10.5:1. I feel I am giving up an honest 10-12 HP with the lower compression.
Old 02-12-2026, 07:02 PM
Jay S's Avatar
Jay S Jay S is offline
Looks like a 433 XR from Comp, it has a lot of mid range, 9.5 to 10.5 is a good place to be. With that cam in a pump gas combo generally a bigger port will like the higher end of that range, the smaller the port will like the lower end of the range.
Old 02-12-2026, 07:34 PM
P@blo's Avatar
P@blo P@blo is offline
11:1 is the maximum
The Following User Says Thank You to P@blo For This Useful Post:
Old 02-12-2026, 07:45 PM
ta man ta man is online now
I'm at 10.8 to 1 with SD's 310cfm KRE heads and SD's OF cam 235/245. Cranking compression is 190. I have zero issues with 91 octane..at times it is a mix of 87 and 91 since I have a pump at home and no issues. Compression is your friend..engine is smoother more power more efficient. I've seen 18mpg with my car a friend of mine has been at 20mpg with a 474 with the same head cam package.
The Following User Says Thank You to ta man For This Useful Post:
Old 02-12-2026, 08:42 PM
charlie66's Avatar
Thank you guys!
Looks like I'll be good then! I was going to try and knock it down some with a thicker gasket with a big bore but looks like I won't have to now.
Old 02-12-2026, 08:45 PM
Skippy597's Avatar
Skippy597 Skippy597 is offline
I errored on the side of caution and went with 10.2:1 after talking with butler. Honestly the performance increase for half a point on a 500hp build is not substantial and isn't worth the chance to me. But mine is a street build.
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235
Old 02-12-2026, 08:48 PM
charlie66's Avatar
Here is the cam card
Old 02-12-2026, 09:34 PM
Jay S's Avatar
I see it has a Bulter part number and it is ground on B lobes. It is the same cam I mentioned, the off the shelf 433, except the 433 is advertised with S lobes. It is generally ground on B lobes though and advertised as an S in literature.
https://www.summitracing.com/parts/c...1/make/pontiac
Old 02-12-2026, 09:54 PM
grivera's Avatar
grivera grivera is offline
What’s the difference between the S and B lobes?
Will Rivera
Old 02-12-2026, 10:07 PM
charlie66's Avatar
Haha I have no clue what that means. Hopefully it will work well with 10.5 to 1. It seems that everyone here is doing it, so I feel better now about it.
Old 02-12-2026, 10:11 PM
charlie66's Avatar
Wow that is the same cam! interesting . Butler told me that it was there won custom design. I guess they made it there's by changing the 520 lift to a 521 . lol
The Following User Says Thank You to charlie66 For This Useful Post:
Old 02-12-2026, 10:14 PM
Jay S's Avatar
The B and S are just suffix’s for the grinders to adapt the lobe to different cam tunnels. Th B is for a little bigger base circle and cam tunnel up to 50 mm. It more or less is adding a slight amount of intensity and lift (.001”) without increasing the lifter acceleration. It won’t make any meaningful difference on this.
Old 02-12-2026, 11:39 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
The biggest caveat is your tuning ability. If you push it too far and don't have it tuned correctly you will regret it.
Karl
The Following User Says Thank You to 72LuxuryLeMansLa. For This Useful Post:
Old 02-13-2026, 01:56 AM
65 Lamnas's Avatar
As usual, "IT DEPENDS".
I'm running a 400-based 462 with ported O-port 72cc E-heads with the "fast-burn" chambers. My block is zero-decked, and I'm running 14cc dished pistons, Fel-Pro 1016s. After the valves/seats were all done, the chambers were cc'd and the actual SCR is right at 11.0:1. Cam is a CC HR with 238/248 on 112 and about .650" (QNI lobes) with 1.65 rockers.
During break in on the dyno, and subsequent intake testing, we ran 92 octane and now that the engine's in the car, I run 91 octane non-ethanol. 34 degrees of total timing with about 16 degrees of vacuum advance.
I'd still be OK at 11.3-11.4.
Old 02-13-2026, 08:14 AM
Anyone pushing it, degree your cam when installing.
Old 02-13-2026, 10:01 AM
That is certainly the MAJOR factor when determining the maximum compression ratio. Not based on my personal experience with Pontiac engines. But with other brands, all things being equal, you can get away with a full point of extra compression or even more with something like a Progression ignition system, port fuel injection, and a knock sensor system.
Going full "old school", like my Pontiac engine, mechanical/vacuum advance system, 2X4 Carter carburetors, no electronics, you have to play on the conservative side to be safe.
Old 02-13-2026, 10:13 AM
charlie66's Avatar
So, with a carburetor and a MSD distributor with vacuum advance and a 6al box is 10.5 to 1 still a save zone for 91 octane for street driving?
