Old 02-17-2026, 06:18 PM
John Milner's Avatar
John Milner John Milner is online now
Default L2394 Domed Piston Rings
I am wanting to use a set of .030 domed L2394 455 TRW pistons in an engine. I am guessing the ring size to be 1/16 1/16 and 3/16. Can anyone confirm that this is the ring size?
These are the rings that I am considering for the engine:
https://www.summitracing.com/parts/TSR-CR3455-30
Should these work for these pistons?
ID:	665181   Click image for larger version
Old 02-18-2026, 06:16 AM
steve25 steve25 is online now
I would have to confirm that for you this afternoon when I get home to dig out my old TRW catalog, but in general stock 455 pistons where not 5/64 5/64, the 2nd ring was smaller.
Old 02-18-2026, 07:53 AM
johnta1 johnta1 is online now
Does Summit show TRW/SP pistons for Pontiac?
It should be the same rings for all of them.
Seems it was like in your link.
Not sure of the oil rings though.
1/16" 1/16" and 1/8" maybe?
Could be 3/16" for oil rings but wait for Steve's catalog info I guess.
Old 02-18-2026, 10:11 AM
Thanks for your replies. That would be great if you didn't mind looking these up in a catalog, Steve. It would be greatly appreciated. These appear to have different ring sizes than some L2359 flat top 455 Pistons that I have. The domed pistons have narrower ring grooves.
Old 02-18-2026, 10:23 AM
Steve C. Steve C. is offline
I have a 1999 Speed-Pro catalog.
It has a Power Forged piston listed under Pontiac with these numbers:
L2394NF 4.151 bore
L2394NF 30 4.181 bore
Both listed with the following:
1/16 1/16 3/16 Rings
19.3 Dome Volume
.476 Dome
1.500 Comp Dist.
0.0050 Bore Clearance
Old information here:
Old 02-18-2026, 12:59 PM
Great, thank you for that information. I appreciate it. I will go with the Total Seal CR3455 30 rings.
Old 02-18-2026, 06:14 PM
Here yah go.
Before you order any set of rings measure how deep the ring grooves are in these pistons and call total seal to confirm that there rings will just tuck into the groove.
Old 02-18-2026, 06:32 PM
Thanks Steve, I will measure and will give Total Seal a call. Thanks to everyone who replied and helped. I appreciate the help.
Old 04-06-2026, 04:32 PM
Just to report back on this in case anyone else has this question, the total seal rings I listed worked perfectly on these pistons and sealed off nicely within the first 5 minutes of breaking the engine in.
The Following 2 Users Say Thank You to John Milner For This Useful Post:
