Old 03-11-2026, 06:42 PM
gtospieg gtospieg is offline
Default roller rockers
Building a 433 stroker w KRE heads and wanted to get roller rockers. Preferably full roller rockers and 1.5 ratio should be fine. Recommendations please.
Old 03-11-2026, 07:36 PM
Neil Scott Neil Scott is offline
I would stay away from cheap knock offs. Scorpion Pontiac rockers, the Harland Sharp race series or Comp. Are good. I have used. Them. . And of course Crower Stainless steel are a great option.
The cheaper rockers like the Speed Masters are noisy,I did not like them due to how noisy they are and would not recommend.
Old 03-11-2026, 08:05 PM
moneypit's Avatar
moneypit moneypit is offline
I've been running the Scorpion 1.5's on my 37 for about 4 years now. I've had no issues. I bought them through Butler.
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
71 GTO base 400 A/T
97 F250 7.3 turbo diesel
Old 03-11-2026, 08:21 PM
JLMounce JLMounce is offline
I've had Harland Sharp 1.5's in service now for 11 years and thousands of miles. The same rockers have been on two different engines.
-Jason
1969 Pontiac Firebird
Old 03-11-2026, 09:40 PM
tom s tom s is offline
I have been running H&S for as long as I can remember.Have used them for pretty much all my builds.Tom
Old 03-11-2026, 10:31 PM
P@blo's Avatar
P@blo P@blo is offline
Harland Sharp here too and never an issue. Very good customer service as well.
Old 03-12-2026, 07:39 AM
Be sure the pushrod socket promotes low friction for easy spin.
Nothing like a Roller Rocker that prevents the Pishrod& Lifter from spinning.
Old 03-12-2026, 08:58 AM
Thanks for the responses. I thought I'd heard good things about HS and Scorpion, so your comments confirm this. I've also heard that there are problems with the Comp. rockers, bluing from heat due to interference with the ball and socket. Has that problem been addressed?
Old 03-12-2026, 09:27 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
HS and Howard's 1.65s on 2 different engines, both great
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 03-12-2026, 10:00 AM
78w72 78w72 is offline
That issue with comp roller tip rockers has been addressed a few times on here over the years, some dont like them & claim ALL of them have blueing or heat problems and that is simply not true.... there was a bad batch or maybe user error that caused or contributed to those problems, yet 100s of thousands of them in use dont have any problems. I for one have a set in use for 10k+ miles & like 30+ years used on 2 different engines that see above average abuse & high (5500-6000) rpms. Lots of others on here use them that report none of the problems.
As with most things like this you only hear about the small number of problems when the large majority are working perfectly fine.... theres reports & pics of H/S rockers breaking too, doesnt mean all of them are gonna break!
Old 03-12-2026, 10:36 AM
Keep in mind some rockers have a spring PSI limitation, so if you're planning on running a solid roller, you should step up to the stronger offerings.
The PRW stainless ones Butler branded are an option, and half the price of others.
The PRW 'Elite' series are stainless and the same cost as the Scorpions/Comp aluminum bodies.
Interesting Butler doesn't carry the Harland Sharp ones anymore.
Old 03-12-2026, 11:01 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
Been running Harland Sharp here on a couple of vehicles, one set for 20+ years and thousands of miles.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Old 03-12-2026, 01:51 PM
grivera's Avatar
grivera grivera is offline
Depending on your timeline, good used HS pop up here all the time at a significant savings so keep an eye on the for-sale ads.
Will Rivera
Old 03-12-2026, 01:59 PM
scott70's Avatar
scott70 scott70 is offline
Crower enduro
The Following User Says Thank You to scott70 For This Useful Post:
Old 03-12-2026, 05:47 PM
Old Goat Racer's Avatar
We have Harland Sharp on 4 engines with Round port E-heads.
Rocker arm geometry is perfect with these rockers. (With the correct length pushrod).
Everybody knows somthin.
Nobody knows everything !
Old 03-12-2026, 06:21 PM
I ended up going with the HS 1.5's. I liked the
Crowers but they were twice the price...yikes.
The Following User Says Thank You to gtospieg For This Useful Post:
Old 03-13-2026, 09:48 AM
Correction to my post- The set I bought new in the early 90s and have been on 2 different motors over ~30 years have 100k miles on them, not 10k.
Old 03-13-2026, 10:23 PM
ta man ta man is offline
Three different engines ,three different heads, four different camshafts HS rockers. 25 years same set. What no one mentions is customer service..I sent them in for a checkover some of the rollers were sticky..I think it was less than a hundred dollars and sent back in a shrink wrap package.
The Following 2 Users Say Thank You to ta man For This Useful Post:
Old 03-14-2026, 07:05 AM
punkin punkin is offline
I've had really good experience with either the Harland Sharp and the PRW stainless.
1968 Firebird
IA2 522
340 E-heads
Northwind 950 Carb
4L80E
3.50:1 Rear
1969 Firebird
IA2 535
Northwind (Induction undetermined)
3.50:1 Rear
Old 03-14-2026, 09:44 AM
nas t eh nas t eh is offline
I threw a set of PRW stainless in the garbage and called Butler to complain about selling them to me in the first place, put Crower Enduros in. Who wants the risk of roller tip pin material grinding up everything in a very expensive engine. Maybe if Pontiacs were as cheap to replace as a Chev small block.
73 T/A 455, 4speed
The Following User Says Thank You to nas t eh For This Useful Post:
