Old 03-13-2026, 09:06 PM
Tim Corcoran's Avatar
Default Doug's Headers & Oil Filter
Some people have had issues with Doug's Headers and not having room for the full size filter. I just installed my 1-7/8 round port Doug's and have plenty of room for the full size filter. Just an FYI
By the way these headers are a work of art. I paid the extra dollars for the ceramic coating and I love them.
ID:	666239   Click image for larger version
Tim Corcoran
The Following User Says Thank You to Tim Corcoran For This Useful Post:
Old 03-13-2026, 09:17 PM
performerrpm's Avatar
i bought a set of those for my sons car...i wondered if they fit as good as they look. his is still on the shelf until he gets back home
Old 03-13-2026, 09:51 PM
JLMounce JLMounce is offline
I really like my dougs headers as well, great pieces. However on my first gen Bird, there is not enough room to get a full size oil filter in place. I use an LS sized wix and do my oil changes more frequently.
-Jason
1969 Pontiac Firebird
Old 03-13-2026, 10:09 PM
Gary H's Avatar
Gary H Gary H is offline
In my experience the issue of getting a full-size filter in there with Doug's headers only occurs with a stock manual transmission bellhousing. I've had to cut off part of it on the passenger side for clearance in the past. Automatic transmissions don't seem to have an issue.
The Following User Says Thank You to Gary H For This Useful Post:
Old 03-14-2026, 12:01 AM
ANDYA ANDYA is offline
That is plenty of clearance. Looks like you might be able to fit a WIX 51049 which is the extra long filter. I’m getting ready to order Doug’s D-port headers for my 65 GTO. I hope they fit as good as your round ports
Old 03-14-2026, 02:25 PM
dv657172's Avatar
dv657172 dv657172 is offline
ANDYA - Pls chime back in on how the D port headers fit on your 65 when you install them
1965 GTO Cameo White, Red Interior - 389, ST300 numbers matching
1965 GTO Black, Black Interior "Post" car - 389, M-20 numbers matching
1965 GTO Silver, Black Interior 100% dedicated drag car w/1968 400(461), 16x Heads, TH400, 3.90 9" Rear 1.656 60' 7.566 90.057 (1/8th)
1971 GTO Black (orig. Quezal Gold), Gold Interior - 400, TH400 numbers matching
1972 GTO Cardinal Red, Black Interior - 455, TH400 almost numbers matching
The Following User Says Thank You to dv657172 For This Useful Post:
Old 03-14-2026, 04:37 PM
Will do. Still working on assembling the short block. Will post something in the exhaust section once I get the motor in the car, hopefully by early summer.
Old 03-14-2026, 05:13 PM
grivera's Avatar
grivera grivera is offline
The braided transmission cooler lines help - metal lines make for a tighter fit.
Will Rivera
Old 03-14-2026, 05:24 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
I had the Doug's for my 69 GTO and while my new engine with stock heads was on the engine stand, I did a pre fit of the headers to my engine.
I found that the headers hit the rear of the pass side of the block when the headers were mounted, this was not some thing that you could see with the engine mounted in the car. Of course an adjustment with a ball peen hammer made life better, but no thrill beating on those ceramic coated headers.
color me gone
