Old 03-22-2026, 12:13 PM
LKLusza's Avatar
LKLusza LKLusza is offline
On my GTO, the PO applied the fender decals within the reference area the manual calls for, but crooked. It always bugged me but not enough to try doing anything until I had time to research decal removal and application enough to not risk damaging the paint.
It seems the Pontiac assembly manual only gives reference measurements for the placement. The problem I see is that the vertical measurement, being from the fender crease coming down, is a poor method for location in that direction due to there being a subtle arch to the crease. If the decal were applied without the benefit of a fixture or jig, the "level-ness" of the decal is at the mercy of the line worker's eye. The horizontal reference coming from the door opening edge was not a problem.
My solution was to use a laser level like that used to install kitchen cabinets to apply the decals on a line parallel to the lower rocker panels. I mounted the laser to a tripod and set it level to the rockers. Then it was just a case of cranking the mount up so the laser line was level to where the original decals had been and then placing painter's tape guides for the new decal. Once that was done, I could remove the old decal and clean the area prior to installing the new decal.
The important part was to use a human hair dryer instead of a heat gun. I also monitored the surface temps of the fender with a thermal heat gun I have. When the surface got just over 100 degrees, the vinyl decals could be started with a fingernail. When enough was lifted, I held tension only on the decal with long-nose needle nose pliers, while concentrating the heat on the glued area of the decal that was releasing from the fender. With tension only, you can feel the glue letting go as the heat hits it. It's that release of the glue that determines the speed of removal - you have no say in the matter.
Once removed, the area was cleaned with Goo Gone and then an alcohol wipe, followed by a buff dry with a clean terry cloth towel. The decals applied easily and the result is just what I was looking for.
Name:	01 GTO Fender Decal Placement.jpg
ID:	666727   Click image for larger version
ID:	666728   Click image for larger version
ID:	666729   Click image for larger version
ID:	666730   Click image for larger version
Larry
The Following 9 Users Say Thank You to LKLusza For This Useful Post:
  #1802
Old 03-22-2026, 03:13 PM
Shiny Shiny is offline
Great plan, nice work!
  #1803
Old 03-22-2026, 03:15 PM
OG68 OG68 is online now
I did the same for the rear fender.
As numerous threads have noted, 68 decals seem to be all over the place even from the factory.
I didn't have any reference except for some old photos I took in the early 80s. Based on these old photos and the actual measurement of the arrowhead lens, I was able to guesstimate the vertical and horizontal distance from letter 'O' to the lens. This was a Fremont car.
I used NOS decals
Preliminary step; The front and rear of the Rocker panel was level with the floor.
After installation, I noted the bottom of the lettering lined up with the top of the rear fender opening.
ID:	666740   Click image for larger version
ID:	666741   Click image for larger version
ID:	666742   Click image for larger version
ID:	666743   Click image for larger version
The Following 4 Users Say Thank You to OG68 For This Useful Post:
  #1804
Old 03-22-2026, 06:03 PM
carcrazy carcrazy is offline
Installed the pilot bearing (not bushing) for my recent build. Hopefully the bolts for the new flywheel and clutch will show up tomorrow or Tuesday so I can get it all ready for installation into the car.
The Following 2 Users Say Thank You to carcrazy For This Useful Post:
  #1805
Old 03-22-2026, 10:17 PM
Installed Tasmanian Devil floor mats.
Drove it and did a little burnout in honor of Taz.
Because it was the right thing to do.
ID:	666755   Click image for larger version
ID:	666756   Click image for larger version
ID:	666757   Click image for larger version
ID:	666758   Click image for larger version
The Following 6 Users Say Thank You to b-man For This Useful Post:
  #1806
Old 03-22-2026, 10:45 PM
I used NOS decals
You look spot on OG68
ID:	666760   Click image for larger version
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
The Following 3 Users Say Thank You to salem1912 For This Useful Post:
  #1807
Old 03-23-2026, 12:34 PM
Took it on a 200 mile run through the California foothills.
The Following 4 Users Say Thank You to 71GP76TA For This Useful Post:
  #1808
Old 03-24-2026, 01:36 AM
jhein's Avatar
jhein jhein is offline
I'm in the process of resuscitating my fuel system upgrade. I started last fall but was thwarted by the Flu then winter. I went out today and assessed my situation. I'm about half way there but right now I'm also dealing with the urgency of post winter clean up and spring time chores on the property. I have mulch and soil coming and some other things. But. I'm getting closer. LOL.
The Following User Says Thank You to jhein For This Useful Post:
  #1809
Old 03-24-2026, 09:37 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Wash, wax - ten gallons of the good stuff
Go fast, see Elvis!
The Following 7 Users Say Thank You to PAUL K For This Useful Post:
  #1810
Old 03-24-2026, 10:39 AM
Here in Portugal almost all your tax/fiscal stuff is lumped into one place. My insurance agent noticed that an annual fee of 992€ for the Pontiac was due 18 Abril - eep! He also noted the amount should be a lot less as the Pontiac is registered as a "car of interest".
Drove it to the Portugeuse tax authority in Palmela (the one much closer in Montijo has some notoriously rude workers). The nice gal there noted the error and zeroed out the amount due.
The Following 3 Users Say Thank You to Scarebird For This Useful Post:
  #1811
Old 03-24-2026, 01:48 PM
67drake's Avatar
67drake 67drake is offline
Wish I could post videos here. The upholstery shop sent me a great video of the progress on my ‘55 Catalina. It should be done by March. Headliner looks outstanding.
‘55 Catalina
The Following 2 Users Say Thank You to 67drake For This Useful Post:
  #1812
Old 03-24-2026, 02:47 PM
jhein's Avatar
You can make yourself a YouTube channel very easily and upload your videos there then just post a link here.
  #1813
Old 03-25-2026, 05:43 PM
form74's Avatar
form74 form74 is online now
Changed the fuel filter on the 75 Formula I got last summer.
It was nasty. I asked my buddy who I got the car for and had it for over 10 years and he said he never changed it so who knows when it was last changed.
Also swapped out the lock and gas cap with a stock cap. The last one was a pain in the butt.
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
The Following 3 Users Say Thank You to form74 For This Useful Post:
  #1814
Old 03-25-2026, 05:53 PM
Originally Posted by form74 View Post
,,,Also swapped out the lock and gas cap with a stock cap. The last one was a pain in the butt.
Given the rising price of gas I would not throw that locking cap away...
  #1815
Old 03-26-2026, 03:43 PM
tempest1964's Avatar
Worked on setting up my ring and pinion. I think it’s pretty close. Thoughts? Picture on left is drive. Right is coast.
ID:	667014   Click image for larger version
  #1816
Old 03-26-2026, 04:15 PM
KS circutguy's Avatar
Looks good.
The Following User Says Thank You to KS circutguy For This Useful Post:
  #1817
Old 03-26-2026, 05:20 PM
67drake's Avatar
Run it! Looks great
‘55 Catalina
  #1818
Old 03-26-2026, 05:22 PM
67drake's Avatar
I do have a channel. Never thought of that! I’ll have to see if I remember how to do that. Thanks
‘55 Catalina
  #1819
Old 03-26-2026, 05:48 PM
67drake's Avatar
I hope this works. Someone let me know if the link doesn’t work on your end.
https://youtube.com/shorts/fpQCMWIEC...oA1b7LpvOh47bs
‘55 Catalina
  #1820
Old 03-26-2026, 06:17 PM
67Lemons 67Lemons is offline
Works and looks fantastic!
1972 GTO
The Following User Says Thank You to 67Lemons For This Useful Post:
