Old 03-23-2026, 08:10 PM
Joe Joe is offline
Default 66 Slotted adj. rod
While in the Carolinas the last month, I acquired a mismatched Tri power set up.
65 intake, complete correct rear carb partially complete front correct carb, a junk 65 chevy center and complete 66 correct center. My question is this... The center 66 had attached a short slot adjustment rod. I have a repo long slot I need to send out for re-plating. Which would you use for authenticity's sake. Thanks in advance.
Name:	Slotted rod 2.jpg
Old 03-24-2026, 10:42 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
???? the 66 center carb is the large base. The correct 65 center is a small base. 66 will not fit on 65 manifold.
The first one looks more original I think
Old 03-24-2026, 01:00 PM
Joe Joe is offline
thanks. I purchased everything because of the end carb parts as well as the large base 66 carb and linkage. I don't need the 65 intake. Already scrapped the junk 65 chevy unit that was small base.
I believe the rod on the right in the picture is an actual an OEM 66. That is what I am trying to get confirmed for my 66 TP resto.
Regards
Old 04-01-2026, 10:42 AM
Dick Boneske's Avatar
The long slot is correct for '66.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 04-02-2026, 06:35 PM
Joe Joe is offline
OK. Curios as to what the short slot rod was used on. In the GTO resto guide book it says that the short slot was a 66 pc. and was replaced with the long slot at some point.
regards
