| Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
approx 30 passes since fresh, new valves and springs, set up for 850 lift, flow sheets provided to buyer (405 cfm @800ish lift iirc)
65 cc chambers, 1.75 ratio off set T&D shaft rockers, port matched victor with dominator flange, will include 7/16'' tapered pushrods that i used also. $6000 shipped bolt on and go also available after market block rotating assembly piston designed for these heads to give about 14.25:1 for E85 or alky race gas use. NEW 4.31 bore ross pistons, 6.75cc dome, 2.35/1.9 valve reliefs, NEW BWE rings already hung on the pistons which are on (10 passes) GRP 6.8x" aluminum rods used Scat 4.35 stroke crank with SBC rod journals, crank is 10/10. 1967 bob weight balanced to 1/3 of a gram, FM main and rod bearings, included $2800 shipped for complete rotating assembly ready to drop in your block. used ISKY cut away 842 off set bushed lifters only availble with cylinder heads $600 Crower 903 bushed off set lifters, only available with cylinder heads $750 standard journal comp roller cam used with above heads, only available with heads, $400 55mm comp cam used with another set of hi ports made 900+ only availabe with cylinder heads $500 roating assembly currently installed in IA2A on stand never had heads on the block details provided to interested parties. plenty of info in my other ads, if you are really interested. once heads sell all other parts will be available seperately will not respond to known tire kickers. thanks Ames for the opportunity
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car Last edited by mysticmissle; 03-23-2026 at 08:54 AM. |
valves are 2.25/175, will also include dead studs
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
Top end has sold w 842 lifters, both cams available rotating assembly still available
Please
Delete as above prices we're with top end purchase I will repost thank you
