Old 03-29-2026, 10:14 AM
scotty54's Avatar
scotty54 scotty54 is offline
Default Can You Identify This Plug?
This is a 68 Firebird Sprint restomod. New OEM style wiring harness plus a few accessories added. Trying to sort out an electrical gremlin and found this plug exiting the stock steering column. The column has a cruise control stalk but no other components. Could this be for the cruise control? I have a TSM but find the wiring diagrams lacking.
Old 03-29-2026, 01:07 PM
turbo69bird's Avatar
No idea on the plug but I'm curious about this sprint restomod definition
960 HP @ 11 psi, 9.70 at 146.
Old 03-29-2026, 01:37 PM
OG68 OG68 is offline
A 68 factory cruise control stalk only has three wires. Black, Blue and Tan. You have what looks to be an aftermarket (Rostra/Dakota Digital?) plug. Rostra schematic shown.
ID:	667193   Click image for larger version
Old 03-29-2026, 05:40 PM
scotty54's Avatar
Thanks OG. That might be it. Never heard of Rostra but just looked them up.
And Turbo69 - frame off resto with a Global West front and rear suspension, Clifford intake with 3 Webbers, TH200 trans. Looks completely stock until you open the hood.
Old 03-29-2026, 05:41 PM
SRGN SRGN is offline
4 pin Molex connector, check with the column manufacturer or cruise control manufacturer to see what they intended it to be plugged into.
Old 03-29-2026, 06:46 PM
It plugs into a second harness from the cruise control box. Usually located under the hood. But since you have Webers I doubt it's still there.
