I plan on adding a set of Edelbrock no hop bars to my 65 which is equipped with a 10 bolt BOP rear end. When I tested fitment with the factory upper control arm still in place, it appears the Edelbrock anti-hot bar will not work with the BOP without quite a bit of modification? In the attached picture, the blue arrow points to where I believe the anti-hop bar is designed to fit around a fin on the differential, which does not lineup with what I have.
Have any of you installed the anti-hot bars on a similar rear end? Thanks, Dan
1970 Tempest (428 Whitmore, Cliff Q-jet, Doug Nash Five Speed) slowly coming back to life 1965 Lemans (462 Butler, Cliff Q-Jet, Muncie M20 with 3.55s) |
Have you up graded to poly control arm bushings yet?
I know you have those bars, but I would do the bushings first.
Bad idea in the rear arms - will bind them up.
Is there a threaded hole on the bottom finger of the bracket? It may be the one to use to clamp to the web. |
| The Following User Says Thank You to Scarebird For This Useful Post: | ||
Not when there lubed as they should be.
I have never used the Edelbrock version- but I have installed 3 sets of the Genuine Suspension & Lakewood versions on 65-66 GTOs.
To install them on a 10 bolt, there is a bit of grinding (but only on the LS bar) that will be necessary to clear the housing rib. You can see why on the 3rd pic attached.
1966 GTO (Red) WARPATH 469CI TriPower 4-Speed 1965 GTO (Black) TRIPOWR 455CI Weiand Dragstar with 6 Strombergs 4-Speed 1965 GTO (Blue) 3X24SPD 464CI TriPower 4-Speed 1963 Tempest (Red) VIOLENT 440CI 2X4 Mag Nash / T400 (for now..) |
I use the Eddys on mine, and I put the Lakewood version on Dad's car.
Both do the same thing. Yes it has made 60 foot times more consistent and the cars more predictable. They work great for drag radial applications where you want separation. Over time I took them a step further with adjustable upper bars and double adjustable shocks so I could fine tune things. As I added more power I found I needed more rebound control to slow the separation down. |
FWIW, I did use the Edelbrock no hops on an 8.5 years back. I remember I had the same concern, as they didn’t really fit out of the box. I had to do some grinding on the rear end housing and no hops to get them to fit.
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
You can't test fit it with the upper control arm on and the bushing in the rear. You need to unbolt the upper control arm and remove the bushing in the rear.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
I just went through this recently with a 12 bolt rear out of a 65 Chevelle that’s going into my 65 GTO. After doing some research I went with the TA Performance no hop bars. They are very nicely made out of 3/4” thick steel with nice welds. Just like every other brand I had to do some grinding on the rear and also on the bars. The idea is to grind strategically to remove as little material as possible. When I was done the bars looked like they came that way and what I did to the rear was unnoticeable.
| The Following User Says Thank You to ANDYA For This Useful Post: | ||
Thanks Drake!
True. Just getting a looksie before diving in. Have you installed any?
I'd be more worried about dead hooking with a stock-ish 8.2 10 bolt. The 8.5 10 bolt out of a 71-72 Skylark is considerably stronger. Ran one in my old bracket car for a few seasons without issue, high 1.6 60' times. If it was faster I would have done axles, but I didn't have any issues with the stock 28 spline stuff. My GN also had an 8.5, 60' in the 1.4s but I did axles in that car. Both cars ran boxed lowers with poly bushings, stock upper arms.
| The Following User Says Thank You to SRGN For This Useful Post: | ||
I use wagon rear coil springs in all my 65-66 GTOs.
This drastically changes the rear suspension geometry- and makes a car even more susceptible to wheel hop. The No-Hop bars, as can be construed from the name- cure that. I also use Hotchkiss Upper & Lower Trailing Arms & Sway Bars. Here's a good thread you can read on the subject: https://www.v8buick.com/index.php?th...p-bars.395276/
1966 GTO (Red) WARPATH 469CI TriPower 4-Speed 1965 GTO (Black) TRIPOWR 455CI Weiand Dragstar with 6 Strombergs 4-Speed 1965 GTO (Blue) 3X24SPD 464CI TriPower 4-Speed 1963 Tempest (Red) VIOLENT 440CI 2X4 Mag Nash / T400 (for now..) Last edited by 3X24SPD; 04-10-2026 at 06:29 AM. |
| The Following User Says Thank You to 3X24SPD For This Useful Post: | ||
Yes, I've installed them on a couple of 12-bolts and two 10-bolts. I've had to machine some of them to fit properly. First set was from HO Racing and they fit well. In my experience, they completely eliminated wheel hop and work very well.
| The Following User Says Thank You to AG For This Useful Post: | ||
Thanks everyone for the advice and pictures. We were able to get the anti-hot bars installed today. My experience was the same as what you all reported as thry required some fabricating and such. The old bushings of course were there to get out. Can’t wait to get it to the track to try it out. The control arms definitely sit a lot higher!
Check and adjust your pinion angle as necessary now. You will be glad you installed these.
