| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Thanks guys, I do like the shop, Eric is very honest, the only things that are not quite correct in the video is that the Master cylinder did go out the day before I was supposed to pick it up, So I had them replace it and rebleed the system. And on my drive home the "new Thermostat" stuck closed about 1/2 way home, but I was able to let the engine cool down, remove the stuck thermostat, refill the cooling system and made it the rest of the way home.
I Suspect that the way the shop pulls engines contributed to the head gasket failure. I have only used a carb plate one time to pull an engine, the buddy I borrowed it from always did it that way, The time I did it I had a Performer intake on the 400, and the intake cracked shortly after reinstalling the engine, So I never used on again. But I can't prove that is why the passenger head gasket blew, it was 55 years old, and before I got the car it had sat for 20+ years in a dry pole bar, Also it is the only time I have never had coolant get into the oil with a blown head gasket, it was just letting compression gasses into the coolant. I have heard of that condition before, but it was a 1st for me personally. I have since installed a Robert Shaw high flow thermostat, And installed the 1" rear bar on new boxed lower control arms that I found intended for the 1991 and later Police package Caprice's. It should not be an issue finding the roof beacon, the real issue will be finding period correct siren and radio equipment. I have found a set of the "lollipop" lights to mount on the rear package tray though.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) Last edited by camerjeff; 05-03-2026 at 04:41 PM. |
