You mean a new bushing where the yoke slips through or?
Sounds like no gear lube in there.
But that rear end? That's a clanky boi for sure. Pull the cover, lets see what horrors are hiding inside. How many miles on this boat? For those of you that may have missed it, a Grand Safari is a station wagon.
Tranny output is fine as it is supported by the YOKE and bushing in the tailshaft housing. That rear diff sounds EMPTY and or 1/2 million miles? That noise is the "clash" between the pinion gear and the ring gear indicating (judging from the amount of rotation) alot of backlash. If it doesn't make noise accelerating or decceratling it must just be MILAGE. If noisey in either direction you should look at pinion bearings.
My moneys on the spider gears and the crossshaft being worn.
If so hopefully the crosshaft bore hole in the case are not allowing rocking movement. If so then you really got issues that only a new carrier will resolve.
