Trimming a package tray to use the grills that come with 6x9s is a minor sacrifice as the package trays are readily available, and doing so makes a big difference. You can load component 6x9 subs from the top without any trimming to the metal structure, and use surface mount mids & tweeters. There are dual-coil 5x7 low/mid range speakers you could use in the front in stock location, and add surface mount tweeters in the corners. The rear seat divider/metal package tray for many cars are available good-used, some are even repopped. So even if you do cut the metal, it can be repaired. Under-seat and trunk subs are not a very good source of sound, they sound 'muddled' at best. I've tried trunk subs firing into the back seat, and it's worthless IMO. But it is good for finding just about every rattle you can imagine back there! Amps now are so compact, you can pretty much mount them anywhere. I helped a friend mount an amp in a hatchback, used a board that I covered, with velcro on the bottom. Using a D-class amp, it doesn't require monster cables either. For many, 6-10g (quality) wire is fine. Yeah, on the trunk light, the birds have a wire that runs along the deck lid hinge and thru the subframe of the decklid. It doesn't offer a lot of light, and to make it worse, it uses a gravity-type switch that is sketchy at best. The LED light strip is adhesive, as is the sensor. It's an inexpensive approach to a poor original design. The sensor has a dial that you can adjust the length of time is stays lit, and it lights the entire trunk cavity. Pop the lid, wave your hand, done. My 'bird project has a 'green' theme, and all the interior and gauge lights are green. The GTO has a 'blue' theme, same thing. EDIT: Motion sensors are cheap, and come in a lot of types. I think I paid $11 for the one I have. .
. 1970 GTO Judge Tribute Pro-Tour Project 535 IA2 http://forums.maxperformanceinc.com/...d.php?t=760624 1971 Trans Am 463, 315cfm E-head Sniper XFlow EFI, TKO600 extreme, 9", GW suspension, Baer brakes, pro tour car https://forums.maxperformanceinc.com...ght=procharger Theme Song: http://www.youtube.com/watch?v=7zKAS...ature=youtu.be Last edited by HWYSTR455; 05-14-2026 at 09:46 AM. |
Just a quick glance at surface mount speakers:
No sooner I finished typing, I got an email from Restore-A-Musclecar on speaker grills! Scary! Heheh!
https://www.restoreamusclecar.com/pa...mounting-studs The OE type grills tho block a lot of sound, but if you want complete stealth, this is a good option. .
| The Following User Says Thank You to Hammertime For This Useful Post: | ||
