| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Got the oil pressure fittings set up to run oil pressure next to the distributor
Then swapped the brake booster out, what a pain in the a$$ Still need to bleed the brakes
74 Formula Below motor destroyed fall of 2023 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet 75 Formula 400 / 4-SPD matching numbers |
These were a set of TriPower Carbs that I bought 35+ years ago.
They came off a 1964 421 HO- which originally had vacuum actuated outboard carbs Sold the useless (to me) bare ’64 intake manifold to IA Dick Duclow- and ended up with the carbs for free. The carbs had an aftermarket mechanical conversion linkage that someone had installed, and some ugly ass homemade fuel lines.
1966 GTO (Red) WARPATH 469CI TriPower 4-Speed 1965 GTO (Black) TRIPOWR 455CI Weiand Dragstar with 6 Strombergs 4-Speed 1965 GTO (Blue) 3X24SPD 464CI TriPower 4-Speed 1963 Tempest (Red) VIOLENT 440CI 2X4 Mag Nash / T400 (for now..) Last edited by 3X24SPD; 05-15-2026 at 07:08 PM. |
| The Following User Says Thank You to 3X24SPD For This Useful Post: | ||
I initially wanted to replace the ugly fuel lines- but the aftermarket mechanical linkage prohibited installing factory fuel lines that due to interference.
I liked the nostalgia of the aftermarket linkage- which utilized a replacement longer center carb throttle shaft- so I just lived with the ugly fuel lines. I’m sure I probably could’ve fabricated something much nicer years ago with very little effort- but that just wasn’t high on my priority list. Finally decided to change it up a bit- and bought a replacement ’65 center carb throttle body, some factory ’65 fuel lines & factory mechanical linkage.
1966 GTO (Red) WARPATH 469CI TriPower 4-Speed 1965 GTO (Black) TRIPOWR 455CI Weiand Dragstar with 6 Strombergs 4-Speed 1965 GTO (Blue) 3X24SPD 464CI TriPower 4-Speed 1963 Tempest (Red) VIOLENT 440CI 2X4 Mag Nash / T400 (for now..) |
Rear Carb Linkage Arm
Revamped
