A torque limiting impact is hardly accurate, no more accurate than a torque stick on a lug nut. It may be within a 15/20 lb window, but it is in the ballpark, but not accurate as a torque wrench used properly.
I.E. Discount Tire uses a torque limiting device (torque stick) initially on lug nuts, and then finishes the install with a conventional torque wrench finally torquing the nuts to spec. A limiting device isn't the same as using a torque wrench. Video here shows how a torque limiting device is not a replacement for a properly torqued fastener. It also shows how inaccurate a torque limiting device can be. https://www.youtube.com/watch?v=JVY0e5sdWx4 Torque limiting impacts are used on non critical bolts in manufacturing, but they're not using them on rod bolts in an engine. It's not what I consider torqued to a spec. Some people have different definitions of what torquing a bolt are............ ![]() Tightening with a ratchet and socket would likely yield the same result, close enough, but not within 5 lbs. of a spec. Hopefully this information shows the differentiation between a torque limiting device and a properly torquer fastener to spec with a torque wrench. If you don't know, ya don't know. |
