Old 05-20-2026, 11:56 AM
Tying in the frame rails may provide enough twist resistance to where you wouldn't need a 4-point, not sure bc I put a 4-point in already.
I meant to say frame 'horns', not rails, but you get the idea(s).
PTFB makes the front tie in:
https://www.pro-touringf-body.com/pr...sway-bar-brace
It basically does the same thing as tying the front frame horns in.
If you look at the VSE Handbook, Herb welded a bar in between the frame horns, might have been on the 'Cheverra' or 'Silverbird' car.
That handbook is pretty much a must-read.
