Old 05-27-2026, 09:45 AM
JLMounce JLMounce is offline
Yeah that sounds about right.
Not sure about F-bodies, but both my A-bodies with GW uppers & lowers, are getting in the 4.9 - 5.5 range of caster.
If I went with a tall ball joint I would get more, but the AFX spindles don't require them and have been told they won't help.
There's a point at which the knuckle can get too tall. If you look at all the people doing subframes or parts for stock frames, most aftermarket knuckles in the systems are coming in between 1.2" to 1.5" taller than the GM short spindle.
That seems to be the engineering sweet spot for negative camber gain without causing stuff you don't want on a street car.
-Jason
1969 Pontiac Firebird
