Notice the 1.2" difference in lengths between T-350 & T-400 for '70 models? The '70 F-body T-400 driveshaft takes the long Spicer 1310 T-400 yoke. The machined surface, aka, the shaft, portion of the yoke is near 6 1/2" long. That's the longest version of over a dozen different styles of GM usage T-400 yokes. For '71 model Birds, Pontiac went to a longer driveshaft for T-400 & M20/M22 usage. That little over 48 1/2" long driveshaft utilizes 3R u-joint, as does its mating ("med length") T-400 style yoke. '72 models Birds factory equipped w T-400's & Muncie 4speeds reverted back to the small Spicer 1310 u joint & that style was used through the '74 models. Have pulled several clean original F-body T-400 driveshafts over the years, still have at least one '70 version. Back in the early '80's, had a '75 up V8 T-350 Bird driveshaft cut down 5/8" for my '80 when I briefly swapped out its Turbo 301/T-350 for a '70 YZ 400 & PQ T-400.
| The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
Hey OPH, I sent you a PM last week.
1970 Trans Am 1971 Trans Am 1974 Trans Am 1978 Y88 Trans Am W72/auto 1979 10th Anniversary Trans Am 1984 Trans Am 1996 Trans Am WS6 1999 30th Anniversary Trans Am 2001 10th anniversary Firehawk #104 |
