| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
I did it this way when I converted the 63 Tempest to 4-wheel Disc and at the same time installed custom +2" Front Coils from Coil Spring Specialties. I used a tie-rod fork inserted between the opposing wire ropes to tweak the rotation into perfect position.
1966 GTO (Red) WARPATH 469CI TriPower 4-Speed 1965 GTO (Black) TRIPOWR 455CI TriPower 4-Speed 1965 GTO (Blue) 3X24SPD 464CI TriPower 4-Speed 1963 Tempest (Red) VIOLENT 440CI 2X4 Mag Nash / T400 (for now..) |
Pro tip, for most old school front chassis. When needing to get lower control arms off.
Buy one of these. https://www.ebay.com/itm/29753747393...Bk9SR9i3hofTZw Take the top clamp and bottom clamps off. Remove the shock. Put the bolt to the spring compressor down threw the shock hole, place the bottom clamp onto the lower part of the spring and thread the bolt into it. I just use a 1/2' impact to compress the spring. Thoroughly grease the threads on the puller shaft. Easy, but still use safety glasses.
https://www.flickr.com/photos/197745168@N07/ "Of all ignorance, the ignorance of the educated is the most dangerous. Not only are educated people likely to have more influence, they are the last people to suspect that they don’t know what they are talking about."Thomas Sowell Last edited by KS circutguy; 06-05-2026 at 11:59 AM. |
