Curious,
I have a 75/76 400 block with 69 #62 heads. That eventually will be rebuilt and installed in a 66 GTO. Will a rear mounted PCV valve valley pan work? Will have a Tri power on top. Thanks |
Yes, a rear mounted PcV is what was used under a Tripower intake.
If this is an original one be aware that they can internally be coated with a lot dried up oil and carbon that once exposed to fresh oil mist will come loose and can and has clogged off oil pump screens.
I used to cut those covers open and clean them and re-spot weld them when done. Big job. Not necessary anymore. A large enough ultrasonic cleaner will clean those pans as good as new. It takes a little time, but they come out beautiful. I have inspected them with a camera and they look brand new.
Oh, and you will need a set of these to get that 400 bolted into your 66.
thanks to both of you. On the block adapters... My block has the 5 mount bosses, so I believe the adapter is not needed. I am going to first try electrolysis on the pan. If that does not work out, I'll hunt down someone with a large enough ultrasonic cleaner. Thanks again
Joe |
That process is mainly for rust so it might not be of much help.
I did one in a bucket of very hot water that a sprayed two cans of oven cleaner into after I had already sprayed a can into the cover and let that sit for 1 hour. It did a fine job.
also, make sure your timing cover has the dimple to clear the tri-power thermostat housing, although there are alternative methods.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto |
| The Following User Says Thank You to Singleton For This Useful Post: | ||
Mike what do you use in the ultrasonic cleaner?
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
