Old 06-11-2026, 04:47 AM
Onestone Onestone is offline
Originally Posted by Parkman51 View Post
A few small projects over the past two weeks, as I do research on a/c:
First, since CPR has been out of upper door bumpers for the past two orders, and Steele costs way too much, I started learning 3d modeling and made some bumpers myself from flexible rubberized filament.
Attachment 671565
Love it
Old 06-29-2026, 03:51 PM
Parkman51 Parkman51 is offline
The side cover gasket is still a much larger project than I wanted it to be, but it's not quite as bad as the bottom gasket. The side cover butts up against one of the transmission mounts (the old ones, because - thank Providence - the new ones have STILL not come in), but instead of having to take off the entire mount, I just got to remove the broken bottom half. Then out came the cover.
Absolutely caked with grime, of course. Now, I also pulled out the lever seal, and after some searching, found a replacement from Fatsco. Wonderful folks over there. They also had replacement bolts with crush washers already installed, which was great, because I couldn't find this size washer anywhere else. (For those unaware, the side cover has 13 bolts, of which the bottom 5 are under the fluid level, and so require crush washers. The other 8 bolts are not, and only have lock washers.) The seal and bolts should be here in a week or so.
ID:	672658 Click image for larger version
When that's done, I'm going to replace the drain plug seal, and hopefully that will end the Saga of the Leaky Transmission. Then it's back to the windshield wiper hookup - which I think I've finally cracked - and the a/c.
