Old 06-19-2026, 01:57 PM
Terry M. Hunt Terry M. Hunt is offline
Default What product?
Need to clean up some chassis grease that made its way onto suspension parts on a highly detailed restored 65. GTO. I need something that will NOT damage the paint under the dirt/grease, so that may rule out any petroleum based product. What does that leave……citrus based? I recall Prep Sol from decades ago, but not sure this would not bleach out, fade, etc the underlying paint. Also not even sure this is still made. Have some wax and grease remover(forget what brand) but not sure what this would do to paint. Maybe try a test somewhere on my old mini van first. What do you guys suggest!?
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 06-19-2026, 02:23 PM
Cammer-6 Cammer-6 is offline
fresh rags
wipe as much as you can first.
strong solution of Dawn used to wet rags second
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 06-19-2026, 03:33 PM
vertigto's Avatar
vertigto vertigto is offline
CItrus based might dull the paint.
Old 06-19-2026, 09:14 PM
I thought about concentrated Dawn after making the post. Maybe a spray bottle of water for a very minimal, controlled rinse. Don’t want to use a hose and have a million water spots when dry. Anybody else have ideas?
Terry Hunt
The Following User Says Thank You to Terry M. Hunt For This Useful Post:
Old 06-24-2026, 10:13 PM
JJDeville JJDeville is offline
I would try a hot water pressure washer first with no product just hot water to see if you can blast it off.
Old 06-24-2026, 11:03 PM
SRGN SRGN is offline
If you use dawn, bottled water to rinse doesn't leave spots. The minerals in tap water leave the white spots.
Old 06-25-2026, 10:04 AM
burd burd is offline
Quarter car wash. Less pressure that a power washer.
Old 07-16-2026, 09:40 AM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default Like dissolves like
Use WD40 on a rag and it will dissolve the grease and not hurt the paint. Then use a mild detergent to get the residue off.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
The Following User Says Thank You to skunkwerks For This Useful Post:
Old 07-20-2026, 10:02 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
IGL Coatings Tar & Bug remover. That being said, I wouldn’t recommend any other Bug & Tar product on the market (almost all contain harsh things like naphtha, kero, xylene, and petroleum distillates). It’s also one of the few that doesn’t market itself as a “safe” citrus based product (containing D-Limonene, a citrus based solvent paint stripper in higher concentrations).
I usually turn to a product called Formula G510 by Gaylord. It’s a colloidal based cleaner that makes grease repel itself and any other surface, as opposed to smearing the grease many times over until it appears to be gone (but never truly is). It still needs to be diluted to the desired ratio, but is generally safe because the contact time needed to clean is a fraction compared to others. Although I don’t know how easy it is to find locally or what the price is up to now. I picked up a gallon or two years ago.
Edit- I like skunkwerks WD40 idea too. Petroleum distillates, but it’s on/off so quick it’s kind of a non-issue.
