Old 06-20-2026, 01:51 PM
Ronj1969 Ronj1969 is offline
When the motor die’s will it start right back up)
If so then your not running too rich low rpm or at idle, but your lean and or your Distributor is at fault.
Most likely cause then of a high none stable idle speed and the motor dying at idle is a vacuum leak or the throttle is not going all the way back to idle or your mechanical advance is hanging up and not dropping all the way back to your base timing setting.
Steve25 yes it dies actually right before it gets to the stop sign but then starts right up again.
Is there a way to richer that up ?
Old 06-20-2026, 02:11 PM
Kenth's Avatar
Kenth Kenth is offline
With A/T idle rpmīs and mixture screws needs to be adjusted in "D".
What carb and how many turns out from lightly seated are the idle mixture screws?
Is the carb idle/lowspeed circuit adjusted/modified for todays fuels?
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 06-20-2026, 02:45 PM
So the carb is the stock 1977 quadrajet 4-speed carb. I’ve always adjusted by closing air mixture starting engine then then turning the mix screws with a vacuum gauge hooked up once I hit the peak vacumm. Stop then repeat on.The other side I believe it should be about 17lbs ? From the Egr Vacum
