Old 06-26-2026, 10:25 AM
When these cars were new they came with a tiny tire most of the time barely measuring 26" tall. That helps tremendously getting away with a horrible effective gear ratio. People today, me included, install taller larger tires.
The problem with a stick shift is if you're already dealing with a lazy effective gear ratio like a 2.54 with 3.23's, it only gets worse with a taller tire.
Hence the suggestion to go 5 speed and even up the rear gear a smidge. With a 2.87 1st gear your low end problems go away and with a .68 overdrive you gain highway cruisability better than youve ever had before
https://youtu.be/XqEydRRRwqE
Old 07-05-2026, 06:54 PM
SD455DJ SD455DJ is offline
Quote: "I believe Cars magazine had a road test of a ’72 lemans GT with the L78 400, M-20 4-speed trans and a 3.55 Safety Track rear end and they got it down to 14.40’s at 99 mph in quarter mile tests. Now surely they could be exaggerated times, or a super-tuned example, who knows."
Here is the article from the SS&DI March 1972 issue...14.37 at 98.04 mph!
Dennis
ID:	672859   Click image for larger version
ID:	672860   Click image for larger version
ID:	672861   Click image for larger version
ID:	672862   Click image for larger version
The Following 4 Users Say Thank You to SD455DJ For This Useful Post:
