Old 07-15-2026, 09:02 PM
MUSLCAH MUSLCAH is offline
Been in this game for 50 years now..
If it were mine....it's single stage ..all day ..every day.
Especially with black...you can just paint that panel ..if
Some damage should arise
Put 4 coats on it...and you can cut and buff it...
SS black ..blows away B/C with Clear Black..
Just my 2'cents
And if I ever refinish my 67 GTO ..Monteago Cream...
It will be single stage too
The Following 3 Users Say Thank You to MUSLCAH For This Useful Post:
Old 07-15-2026, 11:14 PM
67GTO4SPD's Avatar
67GTO4SPD 67GTO4SPD is offline
I just painted these two trucks with single stage. With aftermarket clear it’s not a matter of if, but when it starts to peel if it’s not garage kept.
ID:	673484   Click image for larger version
ID:	673485   Click image for larger version
ID:	673486   Click image for larger version
ID:	673487   Click image for larger version
‘67 GTO - stock(ish) appearing 406, #16 heads (ported by Steve Magnotti to flow 265/208), 703 Lunati VooDoo cam, 800 cfm Buick Q jet, ported Edelbrock Performer Intake, Ram Air 2.5 exhaust manifolds, M20, 3.55 Safe-T-Track
(Formerly 67GTO4SPEED)
The Following User Says Thank You to 67GTO4SPD For This Useful Post:
Old 07-16-2026, 08:50 AM
I've had all 3 types of paint jobs, lacquer, base/clear, and single stage.
I agree, nothing looks like what lacquer does, but a lot of people won't use it anymore. The T/A had a lacquer job done in the early 80s, and lasted with no issues for over 10 years. I had it painted basically just to change colors, and then painted again 1.5 years ago.
The 442 is black, and painter insisted on SPI single stage, and it turned out fantastic. That was done as a 'scuff & spray' and the blemishes it has is from lack of good prep, but still looks great.
The GTO and now the T/A, both are base/clear. The GTO wish I would have gone single stage, but it is what it is. The T/A was sprayed base/clear because of the specific color I wanted was only available from PPG due to the mica used, and is a limited Jag color. Not cheap ($1900 gal), but it was well worth it.
Old 07-16-2026, 11:00 AM
bdk1976 bdk1976 is offline
General rule of thumb:
Non metallic = single stage
Metallic = base/clear
Old 07-16-2026, 10:36 PM
lintmann lintmann is offline
Man this great just soaking in all the discussions! I'll do single stage, final answer.
For me I would prefer the look of basic lacquer, not because of the deep gloss you can get but because of the nice tight orange peel. This is a restoration and I prefer the original look but the problem with modern lacquer is that it's just so fragile. I had my NCRS inspired Corvette painted PPG lacquer a while ago now and spilt a very small amount of gas near the filler just last summer. I didn't notice until the next day when I noticed a dull trickle mark. After all the panic left I decided to try and polish it out and as luck would have it, the shine came back. Unfortunately if you look at it just the right way, you can still see the damage that the gas did...
Anyways, this Judge will be getting black single stage.
Old 07-17-2026, 11:59 AM
Cammer-6 Cammer-6 is offline
I would chose SPI
I would also cut and buff
SPI suggests mixing clear in the last color coat if thats what look you want
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 07-17-2026, 05:51 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
A '29 Chrysler rumble seat roadster. Not mine, belongs to a member in my club, stock restoration. Black fenders with a soon to be dark maroon body. During this period of Canadian smoke, we're indoors sewing a cream/tan interior.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
The Following User Says Thank You to HoovDaddy For This Useful Post:
